Question about Thomson 28VK25US TV
Maxim 1160 (Thomson) 32" Widescreen CRT - no signal
I was given the above 100 MHz widescreen TV, that's in good cosmetic condition although a bit on the heavy side. I am not sure of the age of the TV, but at I guess I would say 4 years max. I can't get any signal at all, it's all snow with the channel number along with a no signal label and a countdown. The arial/coax is providing a signal - I have no problem with my existing TV. I have also tried a DVD player in one of the SCARTS, but nothing on any the AVs. In fact it doesn't appear to go to AV mode (blank screen at all, but a label suggests that I am - it's still snow. Everything else appears to be OK. I don't mind chucking money at it, but would it be worth it? It also has a band of blank screen of 4CM in hight and another band of blank screen of 2CM at the bottom.
    President:
  • 3,130 Answers
Your going to need the original remote first. then go into the menu and do a channel search on it. if it goes through and finds no channels then the tuners bad. You could have that famous RCA on nboard tuner fault where alot of sheild grounds are bad. This is not a job for the layman. if you cannot get channels by doing a channel scan call out an rca or thompson repair person.
Posted on Sep 22, 2006
SOURCE:
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
Jul 14, 2012 | Toshiba CF32F50 TV
We were just given a pl26 tv, by can not find where to plug the cable connector into the tv, help
this information may help
32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 ...32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 800:1 6ms ... Front Panel Controls: IR sensor ; LED; Top Panel ... Model: PLTV-32; Product Requirements: HDTV receiver
May 05, 2012 | Protron PLTV-26 26 in. HD-Ready LCD...
Tv wont turn on
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
Jan 04, 2010 | Televison & Video
Magnavox LCD HD Flat/Widescreen 1081i .color goes to black and white after about a minute of being on
yes common problem. only way to repair is the digital signal processor which can only be replaced by replacing complete board. sorry
Nov 13, 2009 | Philips Magnavox TS3260C 32" TV
Why does my 32 inch Toshiba keep changing screen format sizes ?
its not your tv. its the program you are watching some show hd picture that fully fit your tv. some still dont have the format for widescreen flat panel tvs. its still
Aug 28, 2009 | Toshiba 32A33 32" TV
Picture stretched on samsung ws32z409t tv
Sometimes on a remote theirs a zoom button or HD zoom if you pressed that the tv will do what you describe if you press it again it will go back to normal view.
Jul 27, 2009 | Samsung WS32Z308P 32" TV
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
Televison & Video Logo
181 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
