Question about Samsung CLX-3160 All-In-One Laser Printer
Printing black problem
When printing black it seems there is not enough ink on the paper
I allready installed new cartridge,it did not help
  • 4 more comments
  • wuhu73 Jan 21, 2009
    The same problem. Even though the print option is selected "Darker" and
    the toner is a new one.
  • rayfreer Apr 08, 2009
    The black print became lighter and lighter with the passage of time. It now is not dark enough to use in professional appearing reports. Is there a way to clean the machine to get the darker ink coloration or has the machine aged to the point it can no longer do the job?
  • Anonymous Apr 18, 2009
    I have installed New black cartridge.It makes good copy.When printing
    print comes out very dim as if low on ink
  • pardoc May 11, 2010
    I need some clarification too, the must be some "blade" on each of the colour+black rollers between the toner tank and the green roller, but I cannot locate them. Nor can I disassemble the unit to clean it.
  • wuhu73 May 11, 2010
    I opened out the front door. Check the cartridge which is full of toner. At the other side there is a green roller. Is this the developing roller. But where is the steel doctor blade at the top? Not easy by looking at the solution in words. A digital photo will help. Will you please. Thanks in advance.
  • George Shamoun
    George Shamoun Oct 25, 2013
    replace the black developer in the imaging unit
This may be solution :
http://www.fixya.com/support/t1281660-samsung_clx_3160fn_prints
As a bonus there is a link to an illustrated cleaning procedure.
Posted on Mar 06, 2009
  • 77 Answers
Check whether bthe devoloping roller of black colour near the drum is full of toner or not. there is a steel doctor blade at the top of dev.roller. the edge of that roller may blocked with toner solids. clean the doctor blade.
Posted on Feb 05, 2009
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
MFC 790cw will not print in black.
garetg,
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Much Regards,
Kyle
Sep 16, 2009 | Brother Multi-Function Center MFC-240C...
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Repacing the color inks with black ink on the epson 1290
Well, since you say you'll be using new cartridges you shouldn't have any nozzle problems. About the worst case I can see would be the slight chance of getting too much ink on the paper resulting in wet paper and a stained platten roller. Seems like an interesting experiment over all.
Nozzle problems arise when reusing cartridges. The very thin metal film that is the nozzle assembly gets worn down as the print head moves over paper and after a number of pages printed the little holes that are the nozzles get larger making for fuzzy, wetter than it should be, streaky printing.
Enjoy,
Carl
Dec 14, 2008 | Epson Stylus Photo 1290 InkJet Printer
Not Printing in black and white
be shure that the cartridge is still full. it hapend to me that the hole ink gone out with no paper printed ... got all over the printer. be shure that the cartridge is wery god installed .... push hard
Aug 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Black ink not printing
To fix this problem I installed a new driver and switched the paper settings to high glossey paper...so far it works...black was the only problem...color printed fine.
Dina
Nov 22, 2007 | Epson Stylus C43SX InkJet Printer
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Samsung CLX-3160 All-In-One Laser Printer Logo
183 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
