Question about Water Heaters
Beckett home oil burner
All new parts in beckett oil burner. after z guaged the igniter and gun nozzel the tube is collecting oil? tried resetting nozzel distance to cone, but no difference. burner oil pump filter and screen changed, complete boiler vacumed out, also. sure can use some help? thanks, very much.
  • ROCKSTER611 Nov 03, 2008
    I SURE GIVE THANKS! I, THINK " I" GAVE NOT ENOUGH OR THE WRONG INFORMATION ON THIS PROBLEM? THE OIL COLLECTS IN THE TUBE JUST BELOW THE NOZZEL WITHIN THE FIRST 30 SECONDS OF STARTUP. I TRIED USING A 1.00 GPH BY 60A IT IS WORKING BUT, PUSHING OUT A LOT OF FUEL. THE BOTTOM HALF OF THE RETENTION HEAD WAS COOKED WITH HEAVY DEPOSITS AND A VERY SMALL PILE OF DEPOSITS WAS JUST BELOW THE NOZZEL IN THE TUBE. AGAIN THANKS, VERY MUCH!
  • 104 Answers
Problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Posted on Nov 02, 2008
Fagor compact plus
You could have a defective gas control valve or a bad thermocouple. Also check the venturi tubes again. sometimes cob webs collect in them and it may be difficult to see unless you remove them and check.
Good luck,
Marty
May 05, 2014 | Water Heaters
Combustion shutoff system tripped how do you reset it
Rheem FVIR or FV or TRD combustion shut-offs are meant to be reset/replaced by trained service technician.
I asked your question at the Tank forum a while back, and the pros there would not say how to do it, citing liability concerns. They were offended when I kept insisting on an answer, but nobody came forward.
I found a link with interesting information:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Quote from link above: ""Called Rheem. They are now supplying a replacemnt TRD kit, part number SP20246A. ... $0.25 glass part...Said you're supposed to have a "certified tech" install it. But since I had the thing apart 4 times already I did it myself in about 5 minutes. Easier than changing sparks plugs. Now, the thing broke again. Bypassed it with a small binder clip for now."" end quote.
I have personally searched Rheem website, and have not yet found service bulletin for FV or TRD replacement, or a guild for part number by model number.
If my research pulls up complete answer, I will try to post additional information to this thread
Apr 11, 2011 | Rheem Water Heaters
Water heater runs for 40 seconds or so and stops, smell oil oder
Hello STOP!!!!! don't push the reset button any more.You have a ignition/spark problem.You will load the chamber with oil and will cause major problems when it lites off.Replace the ignition TRANSFORMER on the burner.Avalible for (beckett burner) at home depot/lowes.
Sep 20, 2010 | RTO Bock Water Heaters 51E 50 gal 152,000...
Gas water heater: burner doesn't fire, replaced gas control valve
Hello,Don't worry about the rust flakes as every burner collects then and is normal.The new control should click.Please check incoming gas pressure supply 3.5"WC natural gas / 9"WC for LP.Check it at the piolt tube with a pressure dial meter,I assume the water temp now is cold.Did you change the thermocouple also as this provides the power to run the control?
Apr 22, 2010 | General Electric GE SmartWater Household...
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Humming noise with my beckett burner
the beat i can do on this is an educated guess , it would be the pump or the pump motor bearings , but having said that i have also seen these make noise for years and not go out ,I have worked on oil burner about 35 years experience has taught me not to guess parts , so the advise i would give is to find the part and model numbers for the motor on the pump assembly and the pump try to find availability in your area , heating and cooling, hardware store ECT. and wait to see if becomes more defined or fails so you don't spend a fortune on parts you don't need ,**** make sure there are no oil ports on the pump motor bearings 9LITTLE OIL CAPS ECT OR PLASTIC PLUGS YOU CAN REMOVE TO OIL ) IF THERE IS PUT A COUPLE DROPS OF 3 IN 1 OIL AND SEE IF IT HELPS .
Feb 01, 2009 | Water Heaters
Water Heaters Logo
770 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
