Question about Samsung SPH-A580 Cellular Phone
How do i remove the display so i can replace it with anouther
You have to take the screws out from under the battery. The back of the device will come off and the motherboard comes out. Once the screws are loose the whole things can be taken apart.
Posted on Nov 01, 2008
Cruise not available
If this is a message you are getting up on the display, it is normally an indication of anouther fault, you will need to get the engine diagnostic codes and check them out, you can get the details for the codes http://www.bluejag.co.uk/diagnosticcodes.php
Aug 25, 2013 | 2002 Jaguar X-Type
Cannot start car with keyless entry after changing the battery
needs re programing when removing battery that has power then you must have anouther battery connected to keep the settings powered up
Oct 13, 2012 | 2010 Infiniti QX56
Water coming inside when its raining and dont know where its coming from
ifyou have roof racks with the year of your van the sealant that mounts the racks may have dried out and splitting removing the mounts and removing screws partially and applying silicone aaround the bas of screw then retighten should seal ur leak up for anouther 10 yrs or more hope it helps
Jul 26, 2012 | 1999 Dodge Caravan
How do you fix xbox 360 e 74 any assistants would be a lot of help
There are two ways to fix this error.
First Take it to a shop that is able to re-flow the G.P.U.
with out damaging the P.C. board. And then securely
clamp the heat sink down . Im not sure if Microsoft does this.
Second Take the unit apart , remove the G.P.U.s Xclamp
replace with nylon washers and 4 8-32-3/8 long screws
lightly and evenly torque all 4 screws. Place half the
fan over the large heat sink and turn the unit on.
affter 5 min the fan should be at full speed and in
anouther 3-5 min you should get two reds . Unplug
and reassemble . The unit should be working.
If you have any questions just comment and ill respond.
Rob
Oct 18, 2009 | Microsoft Xbox 360 Console
Sound of fan increased in my inspiron1545 laptop
The fan most likely has a fauly/worn bearing or is clogged with dust.
Try cleaning and removing the dust from the fan anf heatsink assembly.
If this doesn't work then replace the fan.
Sep 06, 2009 | Dell Latitude D600 Notebook
How do i reset antitheft?
30 min learn procedure turn on key wait 10 turn off attemp to start leave key on wait anouther ten key off attempt to start leave key on anouther ten turn key off attempt to start should be fine.
Jul 17, 2009 | 1996 Pontiac Grand Am
Hard drive refused to power on. When i plug the adaptor the light on the adaptor will blinking continously but no power on the External hard drive
sounds like the drive has locked up the adapter is powering it but hdd can not turn try removing the hdd and replacing it with anouther.
Oct 24, 2008 | Computers & Internet
PROBLEMS WITH SIM CARD
Probably wasn't set in properly, and metal contact not hitting.
Jun 11, 2008 | Pantech C300 Cellular Phone
Nokia 6310i facia replacment
at the top of the phone their is anouther screw it is located top left near aerial, release this and you will be able to seperate phone fascia
May 22, 2008 | Nokia 6310i
Samsung SPH-A580 Cellular Phone Logo
63 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
