Question about ViewSonic WMG120 Router (DHWMG120B1)
Viewsonic inbound/outbound policies
Does anyone have a clue how to forward ports on this router, because if you do you will know more than viewsonic, every time I phone them they waste 20 min on the phone with me and then tell me they will have to escalate the situation to a higher technician and never call me back, this has happened only 4 times...I am getting a little pissed off. It should be pretty straight forward eh! you would think but there is no option for this, the advanced settings seem pretty straight forward. inbound policy, outbound policies. but nothing seems to work, you would think setting up an inbound policy to forward traffic to any port would do the trick but no it actually puts the ports to stealth mode not open status, do I have to run DMZ on the computer I am opening the ports for, Hey I didn't try that. I will tonight when I get Home from work. Please please if you are familiar with viewsonic router either wmg120 or wmg80 which are both the same firmware I will be very thankful.
  • ViewSonic Master
  • 12,061 Answers
Hi I found a manual that may help. www.viewsonic.com/pdf/ userguides/wmg120-1_ug_eng.pdf - Also there is a Fix at another FixYa post.. here http://72.14.253.104/search?q=cache :-nNNX6MQXNEJ:www.fixya.com/support/ t102098-port_forwarding+viewsonic+wmg120 +port+forwarding&hl=en&ct=clnk&cd=2
Posted on Aug 04, 2007
How Do I Configure Port Rate Limiting on a Modular Switch?
This is the method of configuring Switch:
Configure QoS CAR on an interface to implement rate limiting in the inbound direction. Alternatively, configure a traffic policy with an ACL-based traffic classifier to limit the rate of packets matching the ACL.
QoS CAR cannot be applied to outbound traffic, but you can limit the rate of outbound traffic using a traffic policy or traffic shaping.
Jun 08, 2016 | Electrical Supplies
Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
May 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
Port Forwarding
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Feb 19, 2006 | NetGear FWAG114 Wireless Router
Port Forwarding
Feb 19, 2006 | NetGear FR328S Cable/DSL ProSafe Firewall...
Port Forwarding
Feb 19, 2006 | NetGear FR114P Router
Port Forwarding
Feb 19, 2006 | NetGear FR114W ProSafe 802.11b...
Port Forwarding
Feb 19, 2006 | NetGear DG824M Modem
Port Forwarding
Feb 19, 2006 | NetGear DG834G Router
Port Forwarding
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
Port Forwarding
ViewSonic WMG120 Router (DHWMG120B1) Logo
125 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
