Question about Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 Still problems with clock /timer. Now just shows 00.00 with auto sign so can't use ovens. Can we light ovens with a match?
  • tinling Nov 02, 2008
    Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
    Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them!
    Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Prob took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
I used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
Posted on Apr 18, 2009
  • Trooper007 Sep 26, 2010
    Many thanks for this as was spot on.
    I had tried to remove the hobbs before but the hot plate side i could not see how to so this was the perfect solution.
    I just tapped the connectors up and also a brown wire which was in the way but cooker back in action
  • Blue5570 Aug 20, 2011
    Tried the solution above as follows - Remove the five screws that hold the front panel in place (screws are located under the panel with the heads facing the floor), you then need to lever the front panel forward using a long screwdriver or similar until you see the wires in the back of the clock, using long nose pliers pull out both blue wires so they hang down, one of these wires ends in a plastic connector and one in a metal blade type connector, push the blade into the plastic connector and then wrap round some insulating tape so they stay together, push blue wires back under panel and replace screws. One of the screws (under the clock) is a different shape to the others, if this screw wont go back into the hole pull the clock buttons forward and it moves the threaded part of the hole in line with the hole on the panel.
    Not an ideal solution as you lose the clock completely and since this seems to be a pretty frequent problem with Rangemaster clocks perhaps they could use a better standard of clock in future? Doubtful I know.
    Hope this helps
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
Clock timer is on auto and flashing 0 0. 0
Try turning the power off and leaving it off to the oven for 15 minutes or so. Turn the power back on and see if you can reset the clock.
Dec 02, 2014 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 gas model
I have downloaded the users guide from rangemaster.co.uk which has details of how to change parts & a wiring diagram, Hope this helps. Here is a section..............
5. To Remove Clock
Disconnect from electricity supply.
Remove the Control Panel (See 2). Pull off the timer
control button(s).
Remove the timer/mounting bracket assembly from the
control panel by removing the fi xing screws.
Remove the timer from its mounting bracket by
depressing the plastic lugs on the timer case, at the
same time pulling the unit forward.
Reassemble in reverse order. When replacing leads
refer to the wiring diagram. Check operation of timer.
BEFORE SERVICING ANY GAS CARRYING
COMPONENTS TURN OFF GAS SUPPLY.
Sep 07, 2008 | Rangemaster 110 (Gas) Kitchen Range
Auto light wont fo off
good day,
hope this link below will solve your problem.
ovens
Aug 15, 2008 | Rangemaster 110 (Gas) Kitchen Range
Oven will not ignite
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Jul 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Problem with clock and Auto setting
hi, we've sorted it now, we just pressed the buttons very hard....
Apr 05, 2007 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Gas) Kitchen Range Logo
622 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
