Question about Brother Sewing Machines
Dropped stitches, appears to bring bobbin tread up and jams
My machine is about 35 yrs old and has not been used in a long time. It says it is a BROTHER Pacesetter, Super full automatic. I have oiled it and cleaned the bobbin area. It was sewing just fine for a couple days. I do not have my manuel so I possible have not oiled all the correct spots. What is causing my machine to jam? Thankyou, Debbie Albaugh.
  • 323 Answers
SOURCE: Self winding bobbin
I think you need to push the bobbin winder (with your bobbin on it) towards the handwheel. Press the foot pedal and it should begin winding. If this doesn't solve your problem, post back with more details of what you've done and the kind of problem you are having.
As a last resort, go to Sears and let them show you how to wind a bobbin.
Posted on Jun 11, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 980 Answers
SOURCE: The bottom stitch on my Singer model 360 is loose,
You are adjusting the bobbin the wrong way, first make sure the top tension is about 4 or 5, slacken the bobbin tension off about a quarter of a turn at a time until you can just pul;l the thread through with slight resistence
Posted on Oct 25, 2009
  • 96 Answers
SOURCE: Jamming brand new machine
the tension on the bobbin case needs to be adjusted to needle size and type of fabric the medium fabrics usually use a size 11, light fabrics need a size 9 and heavy like ( corduroy denim or upholstery fabric needs a 14 or 16 Heavy fabrics need a little less tension on the top side so it will feed properly just play with it until it looks good on a scrap of the same fabric
Posted on Dec 13, 2009
  • 96 Answers
SOURCE: Bobbin thread is pulling out easily...not a good
tension on bobbin is too loose
My machine is new (only used once) but now keeps jamming, appears the needle keeps jamming under the plate,please help.
if it' still under warrenty take it back and get another..if it's not under warrenty, try a new needle, make sure the top thread is not coming off the thread take up lever, make sure the bobbin is turned the right way in the bobbin case, also could be a timing problem
Dec 03, 2014 | Sewing Machines
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
Hello when i manualy turn the hand wheel to bring bobbin thread up it does not work. the machine was working fine until it jammed and i noticed the timing was off and so i thought i fixed it because...
I would call Singer at 1-800-4singer and explain this problem because it sounds like the timing again for you, I am sorry to say. You may have messed up the timing when it jammed. Just on the off chance did you put a new 80/12 needle in? I read somewhere when they try to fix the timing they use this size needle to test it. How old is your machine? Who did you buy it from, did you use your credit card? If, so the store you bought from should be able to help you out. It looks like a really nice machine and it is a shame that you have to put up with the problems. You may be able to get an answer from this site better but I am answering you for free and all I have is 50 yrs experience in sewing. Please call Singer and don't take no for an answer.
Oct 08, 2010 | Singer 7436 - INGENUITY
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
I would get a second opinion about the has nothing to do with any cam.
Timing is relationship between Hook and needle, Cam is the stitch type.....if you can make a zig zag, timing is fine and all other stitches will be fine.....(provided tensions are balanced)
If cam is cracked, not all stitches will work, or may not be consistent, but the stitch will be created if the timing is good.
Handwheel tight...probably overtight motor belt adjustment....bobbin winding...well did it work before or is this new ?
Speak to Husky about a reputable service centre and have them take a look at it, they will also be able to advise parts availability if that proves necessary.
Aug 31, 2009 | Sewing Machines
I've tried cleaning the machine, re-threading the
Its still under warranty best bring it back sounds like a broken needle or tread knot.
Aug 16, 2009 | Sewing Machines
Sewing Machines Logo
116 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
