Question about Drills
Makita 8406C Gearbox oil
Hi
I recently have bought diamond core drill Makita 8406C as spares or repair on Ebay i have managed to fix electrical problem but noticed that the gearbox runs without the oil - the question is - does it need any type of grease or oil - if yes can you recommend any product that i can use
thanks
Jarek
j.trawka@op.pl
    Novelist:
  • 99 Answers
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Posted on Nov 08, 2008
Makita 6228d has no torque, is the gear box repairable or only can be replaced?
The gearbox (PN 125087-2) is only sold as a unit, no individual parts are available for it. Torque on a drill is usually a function of the power in the battery and the motor's ability to use it. Unless the gearbox is binding enough to make it or the motor very hot when in use your problem may lie in a 'tired' battery or motor issues like brushes.
Mar 02, 2014 | Makita Drills
Makita 8444d second and third gears sound noisy and do not engage
I had the same problem on my 8444, it was out of warranty (just over 2 years old) so I stripped it and found the plastic gear selector ring worn out. Was livid at this as these drills are marketed on the strength of the "all metal" MXT gearbox! Makita UK, to their credit, sent me a replacement gearbox free of charge when I pointed this out to them.
A year on and the replacement gearbox has now started doing the same in 3rd (high) gear. Doubt I can get another free 'box out of Makita (they would probably say I fitted it incorrectly) so am looking at buying just the drill body, which comes out at around £60 and will work with my existing batteries. Just not sure if I would trust the replacement not to fail, but a similarly powerful drill with 2 batteries would cost me wel over £200.
Jul 20, 2010 | Makita 6349DWDE 18V 1/2" MXT Driver -...
The problem is with the chauck head dosnot spean but the motor is working ther is small part inside wornout(the teath dont catch) the drill i have makita hummer drill 13 mm chuck 14.4 v. thank you
unless you find a repair shop that has a used gearbox that has a shifting collar they would sell, you will need to replace the whole component. they do not sell individual parts for this.
May 23, 2010 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Hilti DD130 Core Drill gearbox Lubrication
Hi
220ml of synthetic 68 gear oil.
Hope this helps
Nov 28, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
Clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Maikita bhp 451 transmissions
the gearbox is good,what the problem is,is the nylon speed change ring that goes on the outside of the gearbox that takes the power of the gearbox,the end of the teeth,about 2mm or less strip making only noise when in 2nd or 3rd gear,,they sell it with the new gearbox and charge you,,,,,but you can buy it separatly,,,the part no.419558-2,,pick key 01820914
Nov 02, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Dec 22, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
792 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
