Question about Zojirushi 5L Water Dispensing Pot Cd LCC50 Black
How do I clean the Hot Water Dispenser?
Instructions for my Zojirushi hot water dispenser are in Japanese only, as are the packets of 'pot cleaner'. Also, each pack comes with 3 smaller I use all 3 to clean a 5L pot?
I have zojirushi 4L (model: CD-LCC). I noticed that the bottom of the pot have some stain which are looked like "corrosion". What should I do? How to remove it? Please help.
Thank you
Posted on Oct 01, 2010
How do I fix a Zojirushi hot water dispenser that doesn't heat up?
definitely made it worse and sadly there is no fixing it. replaceonly
Sep 02, 2016 | Dishwashers
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
How to clean inside it
Boil Vinegar water or lemon juice water (liquid, not fresh lemon) to remove calcium buildup.
Mar 12, 2014 | Tayama N-25A Air-Pot Hot Water Dispenser
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Bunn hot water heater has a slow flow of water
Try brewing a few pots of white vinegar solution, no coffee in the system.
Jan 22, 2013 | Bunn 125000024 Hot Water Dispenser 5...
I have a 90 series washer, about 15 years old, the fabric softener dispenser is not emptying. I have pulled it off and cleaned it, but it only works once after I do that.
I would re-clean the dispenser, use hot water can completely clean this. If you don't add water to fabric softener, it will cake up and cause this issue. This problem can also cause spotting and appear to have issues on clothing. Just soak dispenser using hot water and pressure to clean out all the ports and openings within the dispenser.
I hope this helps, worst case you can replace dispenser, but I would just clean it (cheaper).
Aug 11, 2011 | Washing Machines
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Zojirushi electric dispensing pot
Got greasy white stuff floating inside the kettle, any idea where this comes from? And how to eliminate it besides getting a new one. This unit is over 5 years old. Thanks.
Oct 18, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
Zojirushi 5L Water Dispensing Pot Cd LCC50 Black Logo
2,975 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
