Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
My LCD power light flashes orange and screen is blank and there is afaint ticking noise coming from the monitor. Can anyone help?
  • Anonymous Dec 20, 2007
    My computer monitior wont display an image. When I turn it on it emits a ticking noise.
  • 594 Answers
Look on the power supply board itself, there may be a very small capactior, like a 1 uf maybe about 3-4mm in diameter, replace it or all the 1uf you can find, they are cheap. Get the 105c rated ones at 35 or 50V
Posted on Apr 03, 2012
  • 472 Answers
Due to still having a power light you can bet the power supply is still fine.
The problem will be in the inverter circuit, but more to the point it's actualy one of the CCFL tubes that has blown.
They can be easy to replace, they can also be a complete nightmare.
Hope that helps =)
Posted on Apr 11, 2008
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
Power supply rebuild
You can write to jah2mil@hotmail.com for more info on repairing cost and where to send the power supply for repair.
Dec 24, 2008 | Akai LCT2715 27 in. LCD Television
Screen blank and orange light flashing
I have an HP 2710 in excellent condition. I lost the power supply when moving from Texas to California.
I have since purchased another HP four in one macnine and could easly justify selling this one. My price would be low and I would be willing to ship for a few dollars. I am good at packing so it will not get damaged. Willing to sell for $35.00 and estimate $12.00 for packaging and shipping costs.
Dec 14, 2008 | HP Photosmart 2710 All-In-One InkJet...
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Blank Screen, Flashing orange power light...
1st Idea - Let's take a look under the cover. I'm not sure how tech savvy you are, but I'm sure you're pretty good if you have a soldering iron. Once inside locate the power supply section. See if you see any blown capacitors on it or any other boards. One obvious way is to see if they are bad is if they have bulging up tops. There could be some weak or bad ones that aren't popped up, but let's start from there. If there are any bad caps, they are dirt cheap price wise at an electronics shop. Keep me posted and let em know what you find. - Scotty
Apr 29, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
Aug 18, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
312 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
