Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
No heat in zone with Honeywell rth230B
Our Honeywell rth230B is not turning the furnace on in that zone of the house. The other thermostats in other heat zones are fine but this one will not bring the hot water baseboard heating to that room. We were mighty cold sleeping last night. The display seems ok.
What we tried:
Resetting the filter button.
Using manual mode and the desired temp.
Switching from heat to off to cool and back.
New batteries.
Prior to the no heat problem, radiator in that room had been "gurlgly". We went away for four days and turned the heat OFF then. When we returned, we could not get the heat back on. The pipes could not have frozen b/c it was not below 32 while we were away.
Help us please--
  • 308 Answers
It is not your thermostat, it is an airbound zone. The gurgly noise you heard was that water and air flowing through the radiator. The zone needs to be purged either at the boiler, or through vents on the radiator. Hope this helps
Posted on Jul 20, 2009
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
344 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
