Question about Microwave Ovens
GE Microwave JVM1340 door handle.
My microwave door handle is broken. You have heard this many times. How do I remove and then replace the lower screw in the door handle. It is not visible from the inside or the outside. The upper screw removes easily from inside the door. This is the same problem I have heard about many times, but I have not seen an answer. Have I missed it? I am new to this support. If a part of the door comes apart to access the lower screw, which part is it and how is it removed? Thank you.
  • Anonymous Dec 29, 2008
    I have the exact same problem. Any insights?
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
safenude
  • 124 Answers
SOURCE: I have a GE SpacemakerXL
Thanks for the opportunity to help! To see if this fault can be cleared, do the following:
  1. If your unit is plugged into an *outlet (most times, this is located over your microwave in small cupboards).
  2. If it is, unplug the cord and wait about 30 seconds.
  3. Plug your microwave back in and see if the panel now works.
  4. Go through all the initial setups such as setting the time.
  5. If the fault does not reappear, then you are good to go. If the fault reappears, you will have to call service or replace the product.
*If your unit is hardwired, find the circuit breaker and turn it off for 30 seconds, then turn the power back on.
If you find my assistance helpful, please rate my service. Thanks for using FixYa.com
Posted on Jan 28, 2009
localwonder
  • 6784 Answers
SOURCE: Can you microwave an aluminum tray (ex: frozen meal)?
No, this is not recommended. the newer microwave will not flash but, if you put aluminum inside, it will damage the Magnetron. this creates the heat and, if it is damaged, you will lose the heating action in this unit and the Magnetron is not a cheap replacement part.
I do not recommend inserting any aluminum objects at all.
Posted on May 27, 2009
  • 10865 Answers
SOURCE: How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Posted on Aug 13, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 25, 2009
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
Microwave door handle
Hi have a nie day!
You may use a electric drill and the a screw extractor so the handle be released.
Mar 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Need to replace the handle of a ge jvm1340, the top screw is easy, but the bottom screw seems unaccessible, can you help thanks, JG
There is a piece of trim on the inside of the door.
This trim is rectangular, about 1/2" wide, and goes around the outside of the glass. the trim has rounded corners. Take a knife and gently insert at a rounded corner, prying the trim out. Once you can put a finger behind the trim, you'll find it comes off easily, revealing the lower handle screw.
Jul 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Another broken handle
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle
bogus...use a Torx driver to remove the door screws...careful of the glass. Replace the handle and reassemble. You may want to take digital pictures along the way. Parts available from ge or other online parts guys.
Dec 18, 2007 | GE Advantium SCA1000H Convection /...
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
211 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
