Question about Epson RX620 All-In-One InkJet Photo Printer
Black crtridge will not print. It is a new one. Color carts. all work.
Have repeatedly cleaned the black cartridge--will not print.
Regards.
gordon
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Hello Gord41,
Make sure there is nothing covering the jets on the cartridge. Also how long has it been laying around? it might have dried out, and/or expired. On new printers the cartridges have expirations and it will not use them after a certain amount of time. Also try a printer self cleaning and see if that does anything. If none of that works, it might be the printer. - Vincent
Posted on Nov 23, 2008
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have HP Deskjet D2466 Printer and when i want to print with color cartridge, the black color would be printed as blue color... My black cartridge was exhausted so i only can printed with color...
when the color cartridge has to make black, it uses all three colors. printing blue indicates that the color cart. is getting low on red and yellow. get a new black cart. and a new color, 'cause it' s coming due.
Let me know
May 18, 2010 | Office Equipment & Supplies
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
New black installed; will not print in black ink. Everything else prints!
hi, it is possible that the black cart was not installed properly. Try reseating the black cart and see if it works. You can also try to calibrate the printer. you can do this by pressing the menu button then go down to calibrate printer. after that it would also help to perform a deep clean which can also be found on that same menu. then try to print. If all these fails, try to call the kodak hotline 800.421.6699
Oct 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson Stylys R300 not printing black
have you tryed a head clean? try this if it still does it what i did when mine did this i found it was the ink cart take the ink cart out get a cotten woolplug cut one end off and stick it in the bottem of the ink cart with the other end that still got the wool on just clean insite printer where cart goes regards mark
Sep 04, 2008 | Epson Stylus Photo R300 InkJet Printer
My Epson RX620 black cart absolutely will not print
This problem with ur printer nocil ,u can't clean this better to call epson service person .But one thing before u call just confirm ur catrige wether original or compatible
Jun 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Epson RX620 All-In-One InkJet Photo Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
