Question about HP LaserJet 2840 All-In-One Printer
Printing on right side only
I installed remanufactured yellow, magenta and cyan cartridges at the same time. Although I was printing black text just fine before the change, afterwards all four colors are printing on the right side only...fading from normal print on the extreme right to faint print in the middle and to nothing at all left of center. I have seen this problem described elsewhere and a discussion of a possible carousel misalignment. I am doubtful this is my problem, however, because the right color cartridge is showing when I open the panel after I press the cartridge rotation button. Can this nevertheless be a carousel alignment problem even anyway? And if it isn't a carousel alignment problem, what else could it possibly be? I have a service manual and the mechanical know-how to take it apart, if necessary, but that will be a last resort..... HP 2840 - My wife and I have been trying for several hours to realign the gears. Black Gear on Right Side INWARD and White (two gears) Outward. We are apparantly not strong enough or to stup...........?????. to follow instructions. Any more detail on which gear does what. Thanks - Tommy@wallacehomes.com
  • GEORGE675 May 11, 2010
    a carousel is one of the most difficult things to replace on this printer as well as the most time consuming. usually when this happens.. its easier to just buy a new printer. it take a decent hp tech about two hours to realign assuming there is nothing broken. if in fact the carousel is broken. you can buy it realitvely cheap. RG5-7587 is the part number. i know that doesnt really answer your question at all but from my past endeavors with the carousel on any hp produxts they are just a pain in the ****.
  • Derrick Shearer
    Derrick Shearer Dec 31, 2012
    If you find a good HP tech the job can be done in a matter of seconds. A guy that thinks he knows what he is doing will get the job done but he will go the long way by removing covers and it will take a long time.
  • 47 Answers
It is the carousel that is dislocated. Check the alignment if it's brooken
Posted on Nov 03, 2008
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Magenta and yellow wont print. new cartridges,black and cyan ok cleaned heads
All new cartridges loaded but no black printing. I changed the black cartridge with a second new one but still no black text printing !
Is this Epson 5800 printer a wtite off at this stage ?
John
Dec 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
HP LaserJet 2840 All-In-One Printer Logo
373 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
