Question about JVC HD56G887 56" HDTV
JVC HD56G887 Power/Lamp problem
I have a 56" JVC Rear projection TV that has had a problem with powering on. The service tech came out and took the guts out, went back to his shop and worked on it, and brought it back. Basically, I am still having the same problem (even with a new lamp). When you press the power button, you hear a click, then the fan tries to fire up, and it quickly shuts down with the lamp and power LEDs flashing in an alternating order. Sometimes it will eventually come back on after pressing the power button a few times in a row. But mostly, it refuses to power on at all. Been working with JVC but they arent helping me at all. They say I have to work with my local repair shop (they dont answer my calls anymore, and they had no idea what was wrong in the first place). Any ideas would greatly help out!
Thanks,
Eric
  • 14 Answers
SOURCE: blue power light flashing and TV not working
It sounds like you have a blown lamp. On average i have seen lamps on JVCs cost about $200
Posted on May 13, 2007
ctf1800
  • 4402 Answers
SOURCE: jvc 52 inch hd-ila hdtv widescreen
you have a bad lamp or balast
Posted on Jan 22, 2008
  • 2326 Answers
SOURCE: Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Posted on Apr 10, 2008
SOURCE: JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Posted on Jan 25, 2009
ginko
  • 19396 Answers
SOURCE: JVC TV Front panel power button blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
Jvc hd56fn97 56-inch 1080p hdila rear projection tv with convergence problem, how do i fix this
That set cannot have a convergence problem as it has no convergence circuit, It is a DLP set with a lamp.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
MY POWER WENT OUT NOW THE TV WILL NOT COME ON ITS A JVCAV-48WP30
Unplug the tv for 1 minute, check the power source make sure another electronic such as a lamp or radio works in the outlet. Try to turn the tv back on and if there is no power, no lights at all then the power supply in the tv is the issue and it will need to be serviced.
May 07, 2010 | JVC AV-56WP74 56" Rear Projection...
JVC 52 " Rear Projection TV Blinking Lights and no Picture
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Jul 17, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC HD56G887 went out, no sound or picture. Both LED and power lights are blinking
Jun 24, 2009 | JVC HD56G887 56" HDTV
Please help!!! Problem with JVC DLP TV
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Want turn on
might be just the projector lamp. Eithe connection lose or lamp busted
Feb 12, 2008 | JVC AV-56P575 56" Rear Projection...
Big screen tv repair
There is a short in this TV set somewhere. The TV set is trying to come on but because of the short, the power supply shuts down. No if it is not the over current shutdown, it could also be the main power supply with an over voltage shutdown protection mode. These are solid state TV sets and should only be worked on by trained techs. Good Luck
Sep 28, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC HD56G887 56" HDTV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
