Philips projection tv have sound,no picture
When i turn my tv on i can hear a wierd noise (static sounding inside).usually when i turn it on it takes a few seconds to warm up,but now not even the warming up message apears.i can still can hear the channels,but no picture.i opened up the back pannel and turned the tv on and i can see the first lamp sort of fizzle(static sound!),but they dont turn on.help.
  • frankyx Nov 06, 2008
    philips 60pp9910/17 60inch projection
    Genius:
  • 1,030 Answers
Wha is the make and model of your set
Posted on Nov 02, 2008
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an...
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Jan 17, 2011 | Mitsubishi WD-57733 57" HDTV
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Annoying noise
If this is a projection tv, the sound you are hearing is the color wheel spinning.
Sep 28, 2009 | Televison & Video
Philips 43P8341 will not turn on
sounds like your two convergence ICs are shorted out, plus you probably need two 6.8ohm resistors ICs are part # STK392-120
should be installed by a trained repairman cost about $300-400
Aug 17, 2009 | Philips 43P8341 43" Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
Philips 55PP9401 no sound no picture
When Replacing the (STK'S Power Pak) for this set you must use OEM parts. After market I.C. will not work!!! They will give you problems like you are discribing. D,TV
Dec 14, 2006 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
