Question about Panasonic BL-C30A Network Camera
Unable to access camera through the Internet
I have opened up the necessary port and even have disabled the firewall altogether but when it gets into the viewnetcam configuration it tells me that it fails to connect to the camera from the internet. Anyone have suggestions?
Which port did you open? I found that my isp was blocking both 80 and 8080. Eventually I was able to access the camera with another port. But when you use a non standard port you have to specify this after the url.
Posted on Aug 10, 2007
I am unable to access my company's vpn server.
You may have some needed firewall ports blocked on your router. Turn off the firewall temporally and see if your able to connect. Your company IT folks should be able to tell you what ports they need open.
Oct 20, 2017 | Arris SURFboard SBG900 (49402201900) Modem
On my xbox 360 it says my nat type strict and wont let me join any gamescould you please help me to get my nat open?
This is generally an indication that your router is blocking some necessary ports. Access your router's configuration page, (look on your computer's network adapter for the gateway IP, and copy it into an internet browser,) then forward the appropriate ports to your XBox's IP.
Jul 21, 2010 | Video Game Consoles & Games
Acer aspire one D2501026 netbook no internet connection
First try to disable windows firewall altogether. If that does not help then this could be a problem with your ISP, I have had a similar issue before. Contact your ISP and see if they can help. Hope this helps,
www.PuterCare.com
Jul 03, 2010 | Computers & Internet
Port forwarding
Hi Robert,
let's see if I can shine a little light on your confusion.
To the "port" business:
Ports are simply connection points for different softwares in a computer. You know that websites usually communicate on port 80. That means that port 80 has to be open in a firewall in order to get to a web page. If your port 80 in your firewall is closed - no communication is happening.
Let's say you host a webpage at home, but you don't want anyone to get there easily. You could choose another port (i.e. 801) and if you want to access the page from the road, you had to type "http://www.mypage.com:801" and open that port on your router. If you now want to give access to everyone, but don't want to change your server settings, all you have to do is to re-firect the traffic in your router by saying: "Redirect incoming requests for port 80 to port 801." (This is the public port 80 to the LAN port 801.)
Does this make sense to you?
So...your game on the Wii usually uses ports 28910, 29900, 29901, 29920, 80, and 443. If none of the ports is used by another application, then public and LAN ports are identical (no redirect necessary.)
And here we go:
  1. Open a web browser like internet explorer or Firefox. Enter the IP address of your router in the address bar of your browser. By default the IP address should be set to 192.168.1.1.
  2. You should see a box prompting you for your password. Enter your password now. By default your password is admin. Click the Log in button to log in to your router.
  3. Click the Firewall link.
  4. Select Disable from the Firewall Enable/Disable drop down box. Click the Apply button. Click the Virtual Servers link.
  5. Click the Add button.
  6. The Wii requires you to forward the 80,443,28910, 29900, 29901, and 29920. Go ahead and enter the settings into the Virtual Servers menu. It looks like this:
    IP Address: (your Wii IP)
    Protocol Type: TCP (to be safe: "TCP & UDP")
    LAN port: 80
    public port: 80
    Enable: (tick on)
  7. Repeat the "Add" command and put in all 6 ports.
  8. To open ALL UDP ports your range is 1 - 65535.
Don't forget to click "Save" when your done!!!
A couple more things:
  1. I would feel rather uncomfortable to open ALL UDP ports - it is like leaving your front door unlocked and every portscanner will find you wide open. But if you have to...
  2. To make sure that the IP address you entered for your Wii will stay always the same. you should edit the "DHCP Clients List". Look at your manual page 37/38 (if you don't have one, you can get it here.) This ensures that the ports are always forwarded to you Wii and not to your computer. (If you have questons about this - let me know.)
  3. And while you're on it: there is a new firmware out: version 2.06T13 from 2007. You can get it here.
    But ATTENTION!!! Little nasty line says:
    "Special Instructions: A reset back to factory default is necessary after firmware upgrade. You will need to reconfig after upgrade. Do not use previous config backup's after upgrade." - Make sure to upgrade BEFORE you change all the port settings etc. otherwise you will have ot do it again.
  4. There is a cool webpage to test if your port is open. Go and check it out: http://www.canyouseeme.org/
Oof...So - I think I've got everything... in case I did forget something or it is not clear to you, just come back and leave a comment and we look at it.
Good luck and enjoy!
Jun 15, 2009 | Computers & Internet
Unable to print from the internet using dell printer 948
We had a similar problem that the printer could not print online content (see here).
Turned out to be a Windows firewall problem and reinstalling the software solved the problem.
Just to make sure: open your firewall settings (Start->Control Panel->Windows Firewall) and disable it.
If you can print now form the internet, you found the culprit.
The easiest way to solve this problem is to either re-install the printer software and open the ports or look into your printer manual and find the information about necessary ports that have to be opened.
If you need more help with that come back here and leave more details (esp. which printer you are using) and I'm happy to help.
Feb 07, 2009 | Dell Office Equipment & Supplies
Can not conect to internet because of norton internet sercurity
Try to disable it for a while and check if it is really the cause of your problem . Restore service once connected and check norton settings to allow connection
Jun 26, 2008 | HP Computers & Internet
Netgear Firewall
with the router connected, open Internet Explorer and type http://192.168.1.1 after you log in there is a option on the left for firewall and you can turn it off. If it were me I would use the routers firewall over a software firewall though. By the time a software firewall detects a hack, its already in the PC.
May 19, 2008 | NetGear RangeMax WPN824 Wireless Router...
Multiplayer ip
If you need to open ports on your router just follow the manual. If you need one just add a comment and I'll get right back to you. If this doesn't work do the same. Go slow and follow instructions. This should fix your problems. Keep track of what you do so it can be undone to start fresh just in case this doesn't work but it should.
Firewalls
GameSpy Arcade is 100% reliant on your Internet connection being fully functional. The same holds true for any games that you want to play online against other people. Firewalls and proxy servers are designed to block your Internet connection in order to minimize the chances that your computer will be accessed (or hacked!) by "unwanted visitors." They also have the unfortunate side-effect of disabling many of the things you might want to do online -- like play games -- since these activities depend on your PC making an unimpeded connection to other computers. Therefore, if you are using a firewall or proxy, Arcade may not function properly nor will you be able to download and install all of the files that you need in order to use the software to play games online.
Connecting to different places online requires access through "ports" in your PC's Internet connection, and firewalls and proxies will close certain ports for your protection. This is not always necessary, but you as the firewall/proxy owner are the only one who can open those ports. We can't do it for you - but we can give you some tips on how to configure your firewall / proxy to allow Arcade to work properly.
What is a firewall or proxy?
Firewalls and proxies are software programs or pieces of hardware designed to protect your computer and/or network from Internet intruders. Some of these are:
  • Windows XP Firewall
  • Norton Internet Security
  • Tiny Personal Firewall
  • Zonealarm
  • Sygate (proxy)
  • Wingate (proxy)
  • Internet Connection Sharing aka ICS - provided by Windows 98SE and higher (proxy)
  • Linksys Routers (hardware firewall)
  • D-Link Routers (hardware firewall)
  • Cisco Routers (hardware firewall)
Working Around the Firewall / Proxy
If you are behind a firewall/proxy and are able to change its settings, Arcade needs the following TCP ports open in order to function:
  • 6667 (IRC)
  • 3783 (Voice Chat Port)
  • 27900 (Master Server UDP Heartbeat)
  • 28900 (Master Server List Request)
  • 29900 (GP Connection Manager)
  • 29901 (GP Search Manager)
  • 13139 (Custom UDP Pings)
  • 6515 (Dplay UDP)
  • 6500 (Query Port)
    Disabling firewalls will not work
    Unfortunately, in most cases, firewalls/proxies cannot simply be disabled in order to allow you to use Arcade and your game. Disabling the firewall / proxy will not open the necessary ports. It will simply shut down the firewall/proxy and leave the ports closed. Also, many factors may conflict with your firewall: Internet Connection Sharing, the use of more than one firewall, or your operating system may all cause conflicts that keep you from enjoying Arcade.
  • Special notes to Windows XP users:
    Windows XP has a built-in firewall. If you are using 3rd party firewalls/proxies with Windows XP, you will have to consult both the firewall/proxy developer and Microsoft to determine their compatibility with one another. You will also need to speak to your game's developer in order to determine the game's compatibility with WindowsXP, its firewall and your 3rd party firewall/proxy.
    Disabling / Setting Permissions on Specific Firewall Programs
    We do not recommend disabling your firewall. Disabling it will not make it open up the ports it has already closed. Instead, you need to configure it to allow access to Arcade. This is usually called "giving permission," and can be accomplised quickly by following these steps:
  • Windows XP Service Pack 2 -- The built-in firewall that comes bundled with Windows XP will affect two areas of your Arcade experience: 1) Arcade itself (including the login process, using PlayerSpy, chat, using the Download Manager and playing games) and 2) Hosting any parlor or peer-to-peer games. In order to use Arcade and play games properly with Windows XP, you should follow these steps:
    1) Unblocking GameSpy Arcade During Login: Click the "Unblock" button in the Windows XP firewall prompt the first time you attempt to log into Arcade atfer installing Service Pack 2
    2) Unblocking GameSpy Arcade via Control Panel: If you forgot to click "Unblock" in Step 1, or if you want to be ahead of the curve, you can configure the XP firewall to unblock Arcade via the Windows Control Panel. To do this: Click on Start > Settings > Control Panel > Windows Firewall. In the Windows Firewall menu, Click on the Exceptions tab. If GameSpy Arcade is not listed, Click on the Add Program button, find GameSpy Arcade on the list of available programs and click the OK button.
    3) Unblocking Your Games: This can be done in one of two ways: a) Either wait for Windows to prompt you to unblock the game and click the Unblock button (this usually happens the first time you attempt to host a game after installing Service Pack 2, or; b) Use the Windows Control Panel to add the game to your list of Exceptions, using the same method listed in step 2 above.
    4) Unblocking Ports: You can take the unblocking process a step further by instructing Windows to open the Firewall to all ports used by GameSpy Arcade and most of its supported games. To do this: Click on Start > Settings > Control Panel > Windows Firewall. From the Windows Firewall Menu, click on the Exceptions tab, then click on the Add Ports button. From the Add Ports Menu, enter a port from the list of ports at the top of this Arcade support page. Be sure to indicate whether this is a UDP or TCP port (the list above should indicate which it is).
Feb 12, 2008 | D-Link SWT DSL-504T ADSL MODEM with 4...
Sending emails
There are numerous ports used and methods to send and recieve e-mail my setup uses the pop / smtp method where I believe the default ports are 110 / 25 however my ISP uses two other ports. Routers with port filtering enabled may allow 110 and 25 by default but are unlikely to permit other ports chosen by your or my ISP. The riskier change is to disable all port filtering. The safer option would be to open the ports required by your ISP (as well as closing the default ports that are unused).
In order to achieve this we will need to determine the ports you utilize for e-mail.
We will need to be able to access the router for configuration with a web browser.
A second option is that your computer has a firewall blocking your e-mail ports. However if this were true your e-mail would never work. The process is similar to the router in that the required ports would need to be open or the e-mail program given permission to access the internet in your computer's firewall program.
This could be a lengthy process determining your e-mail client accessing the configuration to determine the ports used. Determining if the router and/or the internal firewall are the issue and making the appropriate changes to one or both as determined necessary. If you, your neighbor or a friend is knowledgeable in these areas it may be easier to have them assist than to do this over the web.
If you wish for me to attempt to assist further I need to know what your e-mail program is? Do you have a firewall or internet security / anti virus product on your computer? What is it's name? Please include the model number of your belkin router.
Dec 11, 2007 | NetGear DG814 DSL Modem Internet Gateway...
Accessing ISP email account
Dec 10, 2007 | NetGear WGR614 Wireless Router
Panasonic BL-C30A Network Camera Logo
1,089 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
