Question about Kenmore 64852 Electric Dryer
Kenmore dryer bought in 2004 stops heating
I replaced the heating element 2 months ago when this first happened which solved the issue. Today it stoped again. I took it apart and the heating element is fine and cleaned it out. I did a diagnostic where I did a timed dry and it worked for 10 minutes. Heat went on and then I put some damp laudry in and then it shut off again and won't restart. I am not sure which part to replace.
  • daveschlee Nov 01, 2008
    The heater element is fine since I can get it to work and heat.
  • daveschlee Nov 02, 2008
    Ok I have checked each of the components and once I reconnected it started up for 20 minutes and then again stopped. How can you tell that the cicuit is bad.
    Scholar:
  • 89 Answers
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Nov 02, 2008
    Scholar:
  • 155 Answers
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s),
  • fixexpert Nov 02, 2008
    thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
    A ohm meter test for these parts is here
    Sergeant:
    Champion:
  • 347 Answers
Hello daveschlee,
Please click here and you will be redirected to a website where you can easily identify the problem your dryer is experiencing.
Good luck and any doubts you have feel free to ask,
Dahaka
Posted on Nov 01, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Click this link for more information to troubleshoot as yourself...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-start
thanks
good luck
  • 435 Answers
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
kenmore dryer bought in 2004 stops heating - dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
kenmore dryer bought in 2004 stops heating - dryer_thermostat.jpgimg src="http://i.fixya.net/uploads/images/dryer_thermostat.jpg" alt="dryer_thermostat.jpg" class="h_mi" /> Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
  • Kenmore Master
  • 19,396 Answers
First check the circuit breaker, if that is ok you must test the heating element, this should be done using a multimeter. If it has blown again replace it.
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Kenmore dryer, heat element ALWAYS on
Good day,
Sounds as if the element inside the canister has shorted to the canister body. You will have to remove the element to check it. I'll include a tutorial on how.
If that doesn't resolve the issue, please reply back.. Whirlpool makes Kenmore dryers.
Jack
http://www.applianceaid.com/wp_element.html
P.S. Look close. It doesn't take much....
Feb 01, 2010 | Dryers
My dryer does not shut off! continues to heat
HI. This is a defective, or damaged timer control module. It must be replace asap. If this continues, it will damage the element. Replace the timer, if possible. Once replaced, the issue will be solved.
Oct 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
Mar 26, 2017 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
No Heat
go to servicematters.com
Jan 15, 2009 | Kenmore 63942 Dryer
Gas Dryer will not heat
I replaced the thermal fuse and it fixed the problem. I had to remove the blower housing cover on the front of the machine to get to the thermal fuse. There was was an incredable amount of lint in there that I cleaned out. I used one of those lint brushes on a regular basis to make sure the machine is clean. That brush doesn't do a very good job. My wife said that the clothes dry about 10-12 minutes faster.
Dec 22, 2007 | Dryers
Open Questions:
My Kenmore 80 series dryer (64852) develops a buzzing sound while drying. Functionally it works just fine. However, after about 20min (this varies) of run time the dryer will usually begin to buzz. The buzzing seems to come and go for a short while and then becomes more constant. Then about 10min (give or take) before the dryer shuts off, the buzzing usually stops. It doesn't seem to matter what setting the dryer in on. (e.g. "Timed Dry", "Automatic Moisture Sensing") Often times when the dryer begins buzzing I can turn the dial back a bit and the buzzing usually stop for a short time. But it seems to pick up with the buzzing again before the dial reaches the same point where it began the first time. Also, because the buzzing remains fairly constant, and I get the impression that the thermostat is cycling things off and on like it should, I don't really think that this is an issue related to the heating element. Although I've been known to be wrong before. As far as I can tell it does have something to do with heat though, because the buzzing only seems to start after the machine has had time to run and warm up for a while and then stops during the last 10min when I assume the machine would be cooling down. Also, I keep the "End of Cycle Signal" in the OFF position all the time. When I have turned it on in the past it sounds distinctly different from the noise it make while drying. One more thing. The buzzing doesn't sound like vibrating parts to me. Thanks for any help you can give.
Oct 30, 2010 | Kenmore 64852 Electric Dryer
Kenmore 64852 Electric Dryer Logo
230 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
