Question about Bosch 11236VS Rotary Hammer
Chuck can't get any bit to lock into chuck
    Novelist:
  • 99 Answers
Probably just the ball come adrift or worn. Depends on teh age of the drill. If you pry the end cap off the tool holder and remove the chuck sleeve you should be able to see the spring lock mechanism. There should be a ball held in place by a dished washer. The ball can come out and get lost so check that. If this is the case it should be very cheap to buy a new ball, and easy to replace. Just remember to lay the parts out in the order you remove them so it easier to re-assmemble them properly. If the ball has jsut dislodged and not fdallen out you should be able to refit it but may need to repalce the chuck as it in this case it is probably worn.
Posted on Nov 04, 2008
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
Top chuck just clicks but won't change bit size?
It sounds as though you will have to replace the chuck. Remove the screw (l/h tread) from inside the chuck first before removing it.
Feb 02, 2013 | Drills
The Chuck on My keyless chuck Rigid drill is stuck. I cannot get the Bit thats in it out. Any suggestions?
lock a pair of visegrips on the bit its shelf and us channel locks and a small rag to turn chuck
Jun 06, 2011 | Ridgid Drills
Drill bit stuck in chuck
Grab the bit and see if it will move in or out of the chuck around a half inch. If the bit will not move at all inside the chuck at all. Lock the bit in a vise and strike the chuck with a rubber mallet. This will usually get the bit out.
Jan 18, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How do you lock the bits in?
Insert sds bit into chuck with slots/slot matching slot in chuck while pulling back on the spring loaded nose. If the bit does not catch try turning/rotating bit to lock. When you release the nose, a pin will drop into the indention on bit and prevent it from falling out during use. Sometimes this pin will break or wear-out thus the bit will not catch. Before you insert the bit, look into chuck for retaining pin. Pulling back on the spring loaded chuck releases pressure on the pin and allows insertion of bit. Parts are available at www.toolpartsdirect.com
Oct 12, 2010 | Hitachi H45MR 12lb. SDS Max Chipping...
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
There is play in the chuck may be bearings. it means drill bit wanders slightly when drilling. drill bits lock in properly but the chuck has left to right play in it
You seem to have found the problem, now you must disassemble the gear head and remove the chuck. Open the chuck jaws wide and look for a screw inside that locks the chuck to the shaft.
Oct 13, 2009 | Makita BHR200SAE Cordless Rotary Hammer
BIT FALLS OUT/ WON'T TURN
try pulling the chuck back at the same time turning the bit while installing it should drop into place release the chuck,then make sure the lever just in front of the trigger is switched over to the rite side to use the hammer action.hope this helps
Jun 20, 2009 | Bosch 11236VS Rotary Hammer
Bosch 11236VS Rotary Hammer Logo
309 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
