Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No power to my KV-32V15
I have a sony tv KV-32V15 and it just stopped working. I have no power when you try to turn it on. No sound and no picture. Do you have any suggestions?
  • 1 more comment
  • Anonymous Dec 08, 2008
    I'm haveing the same problem. But my fuse is ok but no power to the button. I don't know what could be between from the fuse to the button. Any suggestions would help thanks.
  • Bubba2U Feb 17, 2009
    I have the same problem but the fuse is fine. Any ideas? Thanks
  • scootrb Apr 10, 2009
    Just went off! No power what so ever!Possible surge from clothes washer kickin in.? Nothing! Plugged in to surge protected power bar though? Happened once before ..but came right back on> Fiuse? Capasitators(?)..Had same problem with an elecrohome 32" ..Yet came back on after cooling! Thanx!
Unplug the unit, wait at least 30 minutes before beginning work after unplugging. take the back case off, there are 10 screws I believe holding it on. Where the power cord goes into the unit, look on the circuit board and you'll see a fuse. Check the fuse, I'll bet it's bad. Replace with the exact same type. I have the same TV, had the same issue. I'm now enjoying it just as I once was. Good luck.
Remember to be VERY careful when inside a TV, there are power sources that are fatal.
Posted on Nov 29, 2008
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Manual for t.v.
you can download your manual here http://fileshare.eshop.bg/downloadsm/20943/Sony_KV-32V15.html
even though it says 32v15 you will see it is for other sets too , just look for the link towards the bottom that says---
" dowload>> to download file please click here <<download"
and it will give you the choice to save to your computer or you can just open it( with adobe )( pdf file )
Jan 17, 2009 | Sony Televison & Video
Sony TV KV-32v15 Dead Power Supply
you should of recived a 0.01ohm resistor it is wite and sayes sony on it.
its a flame proof resistor that needs to be the very same
look for it on the pcb test it its probly open right.
ask them to send you the right part.
regards,
daniel.
Jan 11, 2009 | Sony KV-32V16 TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Hi, Folks... I have 1994 Sony Trinitron KV-32V15 with this symptom: Turn it on for few minutes, picture showing ok, then collapses to dark brownish backgroud with screen full of horizontal lines...
It sounds like your high voltage transformer is shot and now time to purchase a new one. The cost of repair is too high for the type of tv you own.Sorry for the bad news.
Feb 10, 2008 | Televison & Video
No picture but sound ok
HI,YOUR PROBLEM IS ON THE FLYBACK TRANSFORMER OF YOUR TV. YOU MUST REPLACE THIS BUT BE VERY CAREFUL REMOVING THE FLYBACK.
Nov 22, 2007 | Sony KV-32V40 32" TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
182 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
