Question about RCA P61960 61" Rear Projection Television
BROKEN SHIELD I WOULD LIKE TO IF MY PROCETIVE SHIELD IS BROKEN DO I NEED TO REPLACE BOTH THE SHIED AND THE PART IT PROTECTS. MY SHIELD IS BROKEN PRETTY BADDLY BUT FROM WHAT I CAN SEE THER IS NO MAJOR DAMAGE TO THE OTHER PART BESIDES IT BEING BENT A LITTLE BIT.
    Sergeant:
  • 337 Answers
Behind the protective shield are two plastic layersright next to each other if the front one is not broken and the quality of the picture is good considering the damage to that specific spot on the screen you should not have to replace it,only remove whats left of the broken shield.Be careful not to scratch that front lens.
Posted on Sep 21, 2006
SOURCE:
I have a Barjan Noise Cancelling power mic 4 pin. Colors are Shield, Black, Red and Yellow, have no idea which is what other than shied is ground. Need to wire to a Uniden PC76XL
check it out first . try it on the 76 and see if it works most but not all 4 pins work with other radios other then the one you want it to.
Mar 14, 2018 | Uniden Radio Communications
How do you fix the heat shield under the vehicle?
Put a couple cloths dryer screw clamp bands together
& put around the heat shied & converter
Aug 18, 2014 | Cars & Trucks
Heat shield rattling is it ok if I just take it off with out replacing it ?
heat shield could be broken or loose missing screws to hold it in place.NO bad idea DONT remove heat shield it protects other components from heat damage.heat shields also protect vechicle floor board from getting too hot causing fire.
Sep 12, 2013 | 2001 Mazda Protege
Will not download virus definitions
yes system shield protects you from virus , i you to download files , turn off system shield
Jul 10, 2011 | RTO IOLO System Shield for PC
Wind Shield Replacement- Steps required to replace windshield. parts.
I need to replace my broken wind shield, but I don't know why
Apr 13, 2011 | 1996 Ford F150 Regular Cab
We are having a wood burning stove installed near a wall in dinning room.no fire place.will we need a heat shied so wall will not get damaged or cracked? Installer will follow manufactures instructions...
Nothing wrong with a little added security.
Go with the extra heat shield.
Keep in mind this heat shield can be decorative too!
You will sleep better at night knowing there is little change heat build up will occur on that wall.
Oct 04, 2009 | Dacor 36quot; Internal Blower Wall Mount...
Tchirp sound on my wheels on Audi A4
It sound like you have touch all the base, so your going to need to check the dust shield on the back side of the rotor. Make sure that it has not gotten bent forward towards the rotor and wheel rim area of travel. It's a common thing to happen as the brakes heat up the dust shied warps slightly and if there is not enough gap between the dust shield and rotor, and rim will make the chirping noise you hear. You may not even have top remove the wheel to fix this, just turn your wheel all the way to one side so you can get to the back side of the brake assembly and push the dust shield away from the rotor/wheel area. Good luck and hope this helps. keep me posted. be glad to help you get rid of that Gremlin.
Jul 06, 2009 | 2004 Audi A4
RCA P61960 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
