Hotpoint washer dryer wont drain, cant find a blockage think its not ending cycle
  • 247 Answers
Suggestions:
1. Get the water out by unhooking the drain hose and holding the end low down over a shallow basin. Lift the end of the hose every time you need to pause to empty the basin. This at least should reduce the risk of a flood during subsequent actions. If water comes out only slowly, then you do have a blockage and will just need to hunt for it.
2. Tip the machine backwards against the wall to as steep an angle as you feel is safe. Remove the front cover from the pump (at the bottom of the machine, probably at the front behind the kickplate). Check the pump cavity for obstructions (removing coins and bra underwire from the impeller as necessary).
3. With the machine turned off, gently turn the pump impeller with your fingertips. It should turn in a flippy sort of stop-start sort of way as the permanent magnet rotor tugs at the pole pieces on the stator. If it won't turn at all, the pump has seized - check again for obstructions and if that doesn't help, replace the pump head (see below *** for ideas on this). If it turns smoothly without the magnetic flippy feeling, the impellor has probably come unstuck from the shaft. You could try gluing it back on, but in the long term, it needs a new*** pump head.
4. Next, put the machine on in dryer mode. Look to see if the pump impeller is spinning. If it is, close everything up and see if the machine will now do a complete wash cycle.
5. If you've still got times when the pump won't run when it ought to, you can either replace*** the pump head on spec (which usually works) or connect a multimeter in AC volts mode across the two wires which go to the pump. Every time the pump is due to be running (so when the machine is meant to be draining, spinning or drying), you ought to see mains voltage between these two wires. If you do, but the pump isn't running, you need to replace*** your pump head. If you only see mains voltage some of the times you ought to, this suggest an (expensive) controller problem. If you never see mains voltage there, it could still be a controller problem, or it might be the wiring between the controller and the pump (check the wires are plugged in at both ends, haven't broken off where they go into the plugs, and haven't chafed or broken where they pass over, round or near any sharp edges or moving parts) - or it might be that your test meter leads weren't connected properly - easy mistake to make!
*** Most Hotpoint machines are now fitted with an Askoll pump. This has a "one size fits all" head carrying both motor and impellor that fits onto a pump cavity bespoke to the type of machine you have. Cheap replacements for the pump head are available from domestic appliance shops and on the web (they look like this: http://www.tdspares.co.uk/proddetail.asp?prod=pmp1007). Fitting the replacement is utterly straightforward.
A.
Posted on Nov 01, 2008
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Spin cycle wont function wont drain
The pump is either clogged or burnt out. Check inside the pump hoses for a blockage first then try it again when cleared
Feb 13, 2010 | Whirlpool ET8CHEXSQ Dryer
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
When rinsing/spinning the water comes out of the dispenser drawer
I see this is under the dryer section, i am assuming its a washing machine or washer dryer.
If its leaking from the dispenser during the filling stage, this could be a blockage in the dispenser or as simple as the water pressure is too high,
If it leaks during the spin on the rinse cycle, this is generally a blockage on the outlet area (normally the sump hose/filter) remove the filter if fitted and check for blockages, if ther is no filter on this appliance, you will need to check the sump hose, this is located under the machine, mormally a black hose from the tank to the drain pump, remove from the tank end and look in there, Finally it could be a blockage at the end of the waste hose (grey one) it quite often gets blocked at the sink end.
Hope this helps.
Regards
Sussex engineer
Please rate my help. Thanks
Oct 22, 2009 | Hotpoint Dryers
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint 800 wm 11 goes through cycle but won't spill or drain
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Jan 11, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
