Question about Bryant 462AJC021BA Air Conditioner
Carrier Weather MAker SX58 gas value issue or something else?
I hear a clicking sound coming from the gas value solnoid. It clicks for a second and at that same time the flame goes out. It only does it every 30-45 seconds. The solidnoid gets warm too, could this be the issue? If so, can you jus buy the solidnoid or do you hvae to buy the entire gas value, thank you Eric!
    President:
  • 267 Answers
Gas valves do not go bad that way . you have a dirty or bad flame sensor .find it and wipe it off . there can be a problem with the control board , but it does not happen offten at all
Posted on Jan 15, 2009
Clicking noise as furnace tries to start
If you have a gas or fuel oil furnace, that is your igniter trying to light the fuel. If it does it for a few seconds and quits without lighting the furnace, there may be no fuel getting to the burner. Check for fuel supply - oil tank empty? gas line turned off? etc
Jan 16, 2017 | Cars & Trucks
Repair t 4000
You did not state whether the flame ignites or not. If it doesn't, the check to make sure the gas line to the dryer is not turned off. You should hear the gas valve "click" while the ignite is glowing.
You can "crack" the gas line at the value to make sure gas is going to the valve.
If you have gas at the value, and do not hear the click, then the gas valve is not opening. Either the valve or the controller is not working.
If you are getting a flame but it goes out quickly, then it is possible the flame sensor is bad.
If you do not feel comfortable doing this, call a qualified appliance repairer technic
Apr 21, 2014 | Kenmore Dryers
Weather king furnace problem
make sure fan on auto and on heat
Jan 24, 2018 | Weather King Heating & Cooling
My fridge is making a clicking sound but i asume no gas is coming out. This is because normal the brrrr siund could go on for some minutes but know its a ...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 30, 2010 | Refrigerators
Freezer not freezing, refrigerator warm, hear clicking sound
sounds like a bad starting capacitor ... thats about a 2 inch container mounted on or near the compressor .. it will have wires attached ... dont let the compressor keep cycling like that .. it will eventually damage the compressor and the refrigerator will quit working before long anyhow .. there is a little cooling now only because the compressor is successful at starting now an then but that wont last long ...unplug the unit until repairs are done .. move your food to another cooler .. the click you hear is the thermal overload switch shutting off the compressor power when it gets too hot .. the starting capacitors are not expensive and may have plug in electrical connectors that will make replacement easy .. it could be soldered in and that would make it a bit more difficult but usually there is a plug .. there will be numbers stamped on the capacitor .. thats what you need to get a replacement .. or you could remove it and take it with you to a parts supplier .. sometimes there are two capacitors in one container .. both have to be changed at the same time in that case (one for the compressor and one for the fan) ... there will be a part number and a value number .. the value might be something like "16 MFD " at 300VAC that gives you the value of the capacitor (not the phisical size) that example would be "16 micro farads" .. the 300VAC is the voltage rating
the part number gives you the size and mounting configuration as well as the value .. make sure the unit is UNPLUGGED before working on the capacitor .. if you call a refrigerator repairman then it should take him only about 15 min to replace the part if he has an equivalent part with him ... you could give him the model number of your frig and that you suspect the "starting capacitor" before he comes out ..so he can bring one with him ..
Oct 05, 2009 | Whirlpool ED2SHAXM Side by Side...
Raypak 207a ignition issue
Is the ignitor sparking when it clicks?  If no spark then bad ignitor.  Is gas flowing to pilot?  If no gas then clogged line or bad pilot gas valve.
May 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Gas not coming on Carrier Weather Maker 8000
either the gas valve is not opening or your not getting gas to the furnace.  also the gas valve won't open unless the draft motor comes on.  if the ignitor is trying to light, but there's no gas, it might be a bad gas valve. i would call your closest NATE certified contractor
Nov 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ignition failure
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Bryant 462AJC021BA Air Conditioner Logo
63 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
