Question about Epson Stylus C60 InkJet Printer
Can't print via the network to a shared C60 on a XP machine from a vista machine
I have a C60 that when I have it as a local printer on both my XP or Vista PC i can print fine. When I try to share it I get an "Incorrect printer driver" error message.
  • Epson Master
  • 541 Answers
Vista and xp dont go together try useing xp
Posted on Nov 18, 2008
I'm trying to share my epson stylus c60 printer on a local network. The other computers, one running Vista home premium and one running 64-bit Win 7, can see it, but can't communicate with it or send a...
Goto controll panel and double click on printer and faxes, click on add printer on the computers you want to have access to the printer.
You should get "welcome to the add printer wizard" window up, click next, select the option you want to use, check the "a network printer" and click next. Check "browse for printer" and click next.
You should now have a window where you can choose the printer on the network you want to use, in your case the c60, once selected click next and set it up as the default, click next until out of add printer wizard. You should now have a printer that the computer can use. hope this helps and post back what happens. thanks.
Mar 25, 2010 | Epson Stylus C60 InkJet Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Print sharing
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
I cannot print through a shared printer on my computer network. The host computer itself can print but the clients that prints through the shared printer cannot print.I want you to help out on this issue
Since engrt009 no longer seems interested in solving his problem, I think we can say this is "Solved by Poster".
geconak - this is clearly a network problem - nothing to do with the printer. I suggest you repost this problem in a Windows Vista forum.
Nov 26, 2008 | Epson Stylus C60 InkJet Printer
Sharing cannon printer MP170
If you want to make your printer a Stand-alone device (no need to be connected to a computer, just directly to the router) you may want to look at getting a Print-Server.
But if you just want to share the printers, you will have to install the printer separately on both computers (since they use 2 diff drivers for the printer), then share it on the vista computer. at this point you should now be able to print on both machines
Nov 24, 2008 | Office Equipment & Supplies
D-link DI-524 wireless - lan network connection
Yep. Vista sucks :-)
In the vista machine, you have to turn on a whole bunch of options. Right click Network, hilghlight properties and left click and it opens up Network and Sharing Center. Down at the bottom, you have a list of options. Start by turning on the options you need: File Sharing, Public File sharing, Printer Sharing etc. I'm pretty sure it's already done in the XP machine, but if not, check there too.
It should start to show network files between machines.
Oct 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Sharing a printer between a Vista Home Premium and XP Media Center Computer
Hi cavman6
(01) Is the Vista computer able to access ANY shared resources at all on the XP machine?
(02) Are you running any firewall software (other than the firewall built into the operating system) on either computer?
(03) If you are, please, let us know which firewall software it is and, for now, please, disable it.
(04) Do both these computers have Internet access? (I'm assuming they do but I do need to ask.)
(05) Is the printer currently ONLINE and working properly w/ the XP machine?
(06) Assign *both* computers to the same network WORKGROUP.
(07) Ensure that file and print sharing are enabled on the XP machine. If you'd like, do so on the Vista system, too.
(A) How to on Windows XP
(B) How to on Windows Vista
(08) "Share" the printer on the XP machine (in printer properties).
(09) Can each computer now see itself AND the other computer on the network?
(10) Have you added your user name and password that you're using on the Vista system to the users list on the XP system?
(11) If you haven't done so already, please, do this. The user name should have a password associated w/ it. So, if you aren't using a password on your Vista system profile, assign one then add that user's credentials to the users list on the XP system.
Please, post back here w/ what you've tried and the results, your observations and any other comments or questions.
Thank you
BJ @:)
Apr 15, 2008 | Extended Systems Printer Sharing...
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
Sharing srp350 network printer on win98 to winxp
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Mar 06, 2007 | Samsung SRP 350 Thermal Printer
Epson Stylus C60 InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
