This problem should be removed because:
Problem with Toshiba Satellite A15-S127 (PSA10U-00RESV) PC Notebook
Cannot run the Restart disk
When i run the restart disk, it says press F1 = Ok, so then the next screen says press C if it is ok to restart, the the computer shuts down and i have to run through the process again. It never progresses to the actual restarting part...
Unusual case?
Thanks,
Austin
Solutions (1)
Best Solution
Its MBR is get corrupt. which can not be easily rectified. (with a Startup /Recover disk)
You need to attach an External Hard disk which should be loaded with windows. Make it master after removing jumper.
Once you boot it with and then download the MBR for your OS. Let me know the status uptothis.
my laptop shuts down and attempt to restart but...
this is what is displayed after everything. 640 system RAM passed 894 extended RAM passed system BIOS shadowed video BIOS shadowed ERROR...
My laptop boots with no
My laptop boots with no display, runs through its usual startup routine it seems, then shuts off and restarts itself contiuously untill you...
the problem of my hp
the problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery...
SATELLITE U305-S7448. Vista is
SATELLITE U305-S7448. Vista is badly corrupted and I have no factory restore disk. How can I obtain a factory restore disk? Boot up...
Add Your Solution
driver problem lan vedio wireles
driver problem lan vedio wireles lan modem
loptop model no psc11g-003001 internet-lan
loptop model no psc11g-003001 internet-lan drioer
meu nome e antonio estou precisando
meu nome e antonio estou precisando de ajuda , o meu notbook n/ esta acendendo a tela, e mandei fazer um orsamento, e o...
I have a Toshiba A15-S127
I have a Toshiba A15-S127 I am changing the CDR/DVD to a DVD-R/CDR my new DVD drive is cabke select and my hard drive is...
See all Toshiba Satellite A15-S127 (PSA10U-00RESV) PC Problems
Fix-O-Meter
34
34 people viewed this problem
- 0 people are following this problem. Be the first!
Top Toshiba PC Laptop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
MBR is Master Boot Record which is Firmware helping in bootup PC for All Operating systems.
Since Computer have Techincal Terminology So I have to use them.
AS your Case is critical, I wud like to suggest you to better is call an Expert to repair the LAPTOP manually, you may have to pay the price but it will cost you less than to buy a new Hard Disk or Laptop.
Please vote the solution now, and if you need more assistance let me know.
I have ideas as well as Fix such type of issues, but manually, thats why I already told you To get assistance from a Service Engineer or Technician having related Tools and software to fix your Laptop problem.
If you dont wish to give any voting then thanks.
If you like my advise then give me Helpful.
Best of Luck & Regards,
Puneet Jain
Thanks for your rating. You not need to apolize here. Since you are also worrying to your System Health, and might get fed tired to repair yourself.
Hey more information you can find out in this website, but better to take help and get it repair with a little cost ~ $ 25.
Corrupt BOOT file
Have a Nice Day,
Puneet Jain
View More Comments
