Error code upside down F E. I drained the hose from tube to water level sensor. Same result. Suggestions please?
You will readily find this out by booking a Service Call to have the manufacturers authorised agent take a look at your machine.
You see, this may not be the only problem with your machine. Get the benefit of knowing eyes and minds to give you real peace of mind with a full check up for the cost of a call out.
Poppa
http://www.cdbaby.com/cd/poppamadison
SOURCE: lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
SOURCE: LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it. It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
SOURCE: hall sensor
no you do not have to replace the motor when replacing the hall sensor. unless the motor is not reading on the hall sensor. most of the time it just the hall sensor that needs replacement
SOURCE: drain line lg tromm
its a pretty complicated process to take off the front panel, you will need special tools for this problem, i would bring it to a professional, the easist way is to lay it on the back side and go from there, if not like stated above bring it to a pro.
ps:drain lines hardly go bad on LG's hmm,if it's leaking then it might be the internal supply lines on the top.
just a hint,
shoots dave
[email protected]
SOURCE: where is the motor sensor
go to appliancerepairplanet.vstore.ca to get a sevice manual or help with this.
I have ordered a thermistor, hoping that's it and that I can get to the silly thing. Opening the front panel might be the trickiest part. Hints?
