Question about Whirlpool MH6150XMS Microwave Oven
Microwave on but not heating
We have been having problems with our Whirlpool Model MH6150XMS. If it is in use for 5 minutes or more, it would not heat anylonger. It comes on and seems to be working, but not heating. I would have to unplug for a minute and plug back in to get it to work. This was for about three months. Now it does not heat at all. It comes on as if it is working properly, but does not heat.
Thank you in advance for the help!!!
  • 535 Answers
Chak the microwave coil its has been burned out so u need to replace it
Posted on Nov 05, 2008
  • 435 Answers
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Posted on Nov 01, 2008
    Scholar:
  • 62 Answers
This is going to require electrical troubleshooting. Are you familiar enough with this to take the covers off and do some troubleshooting? If so, I can lead you though what to check. If not, you might want to think about carring it to a repair shop or getting a new one.
Chad
  • 4,472 Answers
It sounds like a problem with the magnetron. The microwave will require service. Your two choices are whirlpool service center or a local repair business. I can assist you with either one. If you have any other questions let me know and once I have more information I can assist you further. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Nov 01, 2008
    http://www.whirlpool.com/custserv/index....
    Follow this link and you can input your zip code to locate the nearest service center and they will be able to assist you further. If you still have any questions or need assistance let me know and please take a moment to accept and rate the solution.
    Thanks again and enjoy,
    Lee
Emerson mm7 microwave stopped heating
The problem is in the magnetron, or the inverter board, "if 7 years old or less" and possibily the keypad control board.
May 10, 2012 | Whirlpool MH6150XMS Microwave Oven
EVERYTHING WORKS ON THE UNIT EXCEOT, THERE ISN'T ANY HEAT.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ..,.,
Nov 11, 2010 | Whirlpool MH6150XMS Microwave Oven
THeood is not getting heated and the turntable is
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and turntable have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, and electronics repair people are not cheap. hope this helps
Jan 14, 2010 | Whirlpool MH6150XMS Microwave Oven
My micro wave will not warm items up
You have not given much information, but it appears the Magnetron element (the heating device) in your oven has failed. Repairs are not cost effective my friend. New units are low priced and have many new features. Consider this.
Nov 13, 2008 | Whirlpool MH6150XMS Microwave Oven
Message for Chad
Hi. Your problem is most likely with the magnetron. I am guessing that it is going to need to be replaced. This is almost always the problem. Here is a link on how to test it. http://www.gallawa.com/microtech/mag_test.html
Be sure and do both tests. You will need an Ohm meter (a multi tester will have an setting for testing resistance).
Just please use caution and discharge the capacitors!!! Working on ANY microwave poses a risk for shock if caution is not used.
Chad
Nov 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave does not heat/cook
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 19, 2008 | Whirlpool MH6150XMS Microwave Oven
MIcrowave oven stopped heating - Whirlpool MH6150XMS
Mar 18, 2008 | Whirlpool MH6150XMS Microwave Oven
Whirlpool MH6150XMS Stopped Heating and Turning
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
The door switch file is at http://www.microwavedisplay.com/doorsw.txt
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 25, 2007 | Whirlpool MH6150XMS Microwave Oven
Exhaust an won't shut off
One of the things that well cause that to happen is the voltage Reg. sticking close. thats only one thing there are 7 others that well do that you need to find a electronic Tech who can look at it for you.
Aug 28, 2006 | Whirlpool MH6150XMS Microwave Oven
Whirlpool MH6150XMS Microwave Oven Logo
32 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
