Question about Olympus FE-210 Digital Camera
One of my pictures wont delete, and the screen says protected how do I change that so I can delete it?
If your pic is in the locked mode (Green Key Icon). Bring up picture. Press menu. Press (Playback Menu) and hit OK. Press OK again and it should bring up the pic with option of off or on. Hit off to unlock and you should be able to delete the pic.
Posted on Jan 10, 2009
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
PROTECTED CARD CANNOT DELETE PICTURE
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 03, 2013 | Fuji Finepix S1500 10.0 Megapixel 12x...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Whenever I try and delete a picture it says memorycard protected and wont let me delete them. how do I solve that?
If you remove the memory card you will see a small slider on the side, to enable or disable write protect.pbnflash.jpg
Aug 08, 2011 | Vivitar ViviCam V7022 Digital Camera
Hi! When i turn my camera on 'protected card' comes up on screen and wont go away? I cannot delete any pictures either?
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 17, 2010 | Cameras
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Coolpix
if your facing the labels of the MMC
you will notice a latch at the upper left corner of the MMC, its a latch
slide it going upwards and it will unlock or unprotect your MMC
re insert the MMC
and try deleting the picture
goodluck!....
Oct 28, 2009 | Cameras
Deleting pics
Hi. I don't know if you accidentally changed something, but I would take all the pictures off. Download them to a pc then format the card. Then, reset the camera back to manufacturer specs. That would fix it.
Rob
Feb 24, 2009 | Olympus Stylus 770 SW Digital Camera
Fuji camera wont work
select the "key" symbol in the menu. select "reset all". If you use sd card there should be a tab on the side of it. slide it to the other position.
Jan 30, 2009 | Cameras
Card locked
There's a little yellow switch on the left side of your memory card labled "lock" with an arrow pointing down. Push it up. Note: If it doesn't work right away, try uploading all your photos to your computer and then dumping them off of the card.  Push the switch up again and it should start taking pictures again.
Dec 05, 2008 | Canon PowerShot SD1100 IS Digital Camera
Olympus FE-210 Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
