Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
PT47WX49E wavy lines
I've owned this TV since new.
Now when I turn it on I get light wavy lines along the top 1/4 of the screen for about 5-10 minutes then all is clear and the picture looks fine.
Any recommendations for the fix of this problem.
Thanks ahead for any suggestions.
  • handydiyer Nov 16, 2008
    Thank you for the reply Bill.
    Is there a schematic of all the CAPs you recommending to replace?
  • 934 Answers
Each component on the board, cap, diode, transistor, etc has a location number prefixed by an identifier, thus c2451 is "c" a cap located at 2451, d2050 would be a diode at 2050 and if you look at the board closely you'll see these loaction numbers are grouped by their circuit. All of the 7xxx will be with a lined area no larger than the circuit they support. A schematic, unless you're a wiz at reading them, won't do you much good because they are drawn by circuit not postion.
Get a good pair of reading glasses and a good flashlight.
Hope this helps!
Bill
Posted on Nov 16, 2008
  • 934 Answers
That unit has a history of bad caps throughout the convergence and other circuits. Personally I believe it was an error in the design.... Check and/or replace the following::: C2451, C3007, C7022, C4613, C2507, C7060 all 100uf/16v and C7127, C7128, C7103, C7154, C7136, C3010, C3008, C3002 all 47uf/16v... You can use a higher voltage rated caps such as 35v or 50v for greater reliability.
Bill
Posted on Nov 13, 2008
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 24, 2007 | Televison & Video
Wavy lines
KIT10 $29.50
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
Jan 01, 2007 | Emerson EWF2703 27" TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
