Question about Konica Minolta Cameras
Looking for minolta auto electro flash 320x series
Minolta 320x number on the shoe is 1159739
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Is minolta auto 25 compatible with nikon d5200
ABSOLUTELY NOT! The trigger voltage of the Auto 25 is much too high and will quickly fry your D5200.
If you really want to use this flash with your camera, you'll need something like this to isolate them.
Mar 18, 2013 | Konica Minolta Auto Electroflash Auto 25...
Wide angle defuser is broken Minolta 5600hs
It's not a problem if you're not using a wide-angle lens. And if you are, you can always diffuse the flash by putting a thin white handkerchief or even a sheet of tissue paper over the flash.
Jan 10, 2013 | Konica Minolta Minolta 5600HS D - Hot-shoe...
Metz flash sony nex camera
Sony NEX 6 has an ATG/Sony's Multi-Interface-Shoe.
Let's hope the Metz 58AF-2 Flash is made for Sony/Minolta, which has an old Minolta's hotshoe.
Contact Sony for the adapter.
Or just buy the Promaster Sony Multi-Ineterface Shoe Adapter, it less than Sony's.
atdlee@netzero.com
Dec 29, 2012 | Metz MZ58321C 58 AF-2 Digital Flash for...
I have this Electro GSN one. When I mounted a normal flash, the flash doesn't function. What is the solution? Does it need a special flash which differently? Thanks for your helps. Reap
You can use any flash that has one contact at the shoe.
Try using the PC flash cord to the flash socket on the camera body and see if the flash fires. If you see flash with pc flash cord and not with the accessory shoe, try cleaning the flash contacts at the hot shoe.
If no flash either using the hot shoe or the flash cord, try testing the flash. If the flash is good, you have to open up the camera to trouble shoot. The flash wire is connected to the shutter's flash contacts.
Jun 01, 2010 | Photography
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta sigma ef-430 st ma flash will not work on cactus v2
Of course not. The electronics inside the flash and the mounting shoe have been specifically designed for the Minolta contacts and required voltages.
Actually, you're lucky if you have not damaged the flash by doing that.
Get a flash with a generic one contact shoe for your cactus.
Oct 18, 2009 | Cameras
Minolta 5600 flash on Sony A200 camera hot shoe problem
This is what you need:
http://cgi.ebay.com/TTL-Cord-Flash-Bracket-Sony-Alpha-A700-Digital-Camera_W0QQitemZ290258666395QQihZ019QQcategoryZ48515QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
it screws into the mount underneath your camera, connects via a cord to your hotshoe mount, and your flash willl then sit next to your camera mounted on this flash bracket.
Sep 12, 2008 | Konica Minolta 5600HS for Maxxum Minolta...
The s/n that i have on my disc wont work when i try to use it in the setup wizard so i can put my pics in my pc
ivitar Entries
May 29, 2008 | Vivitar Cameras
Added flash mount
LOLEE, I'M NOT FAMILIAR WITH THAT FLASH, BUT I HAVE SOME GENERAL INFO THAT MIGHT HELP. FIRST, IS THIS FLASH USING THE CAMERA " HOT SHOE " MOUNT? IF IT IS, ARE YOU SURE THAT THE FLASH IS FULLY INSERTED IN THE HOT SHOE? NEXT, IS THIS FLASH COMPATIBLE WITH YOUR CAMERA? YOU SEE, SOMEHOW THE CAMERA IS NOT GETTING THE INFO THAT THE FLASH IS CONNECTED. I WOULD CHECK ALL CONNECTIONS TO BE SURE THEY ARE TIGHT. HOPE THIS GIVES YOU SOME IDEAS TO WORK ON. IF YOU NEED MORE HELP, JUST REPLY.
ARCLIGHT1217
May 11, 2008 | Minolta Maxxum 50 QD 35mm SLR Camera
Cameras Logo
129 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
