Printer is only printing on the right side of the photo paper
Hi, my CP-220 photo printer is only printing on the right side of the photo paper. I have checked and double checked all the settings and everything seems fine. I have installed the last version of the drivers but the same thing continues to happen. Thanx in advance. Bye, Jorge Yes same problem with CP330 - not used for ages then it wouldn't work. Would ;like to follow solution of glueing possible broken part but can't get the printer apart. 3 screws underneath but cover won't budge. Any tips bearing in mind the poor standard of plastic used?
  • Barnes0615 Nov 26, 2008
    I have the same problem... it prints on only one side. This photo printer hasn't been used for a while but I did put in a new printer cartridge. Anyone??? Help?
  • 90 Answers
Check out the cartridge on the Rack moving completely otherwise clean up the Carriage rack,
remove the Cartridge once and then clean it firmly, its Nozzle and contact strip.
Then clean out with a cotton or paper the carriage rack and contract strip, also the Roller (if you are accessible to that).
If no luck then try for reinstall the printer, and use of new cartridge.
Let me know if you need further assistance. Download the Driver using this link:
Canon CP -220
Posted on Nov 01, 2008
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon cp 220 only prints 1/2 of the photo
There is nothing wrong with the Printer. The problem is the picture settings that are being used in the graphic software. You have not specified which Graphics or photo software you are using. Therefore I will generally tell you that you have to adjust the size and the dimensions of the photo you are printing. Make the photo small enough that it fits your page. Some graphics software also allow you to crop the photo (which means you zoom on a certain important part of the photo and bite it off and that part is sent for a print to printer). This whole game is in the software. Another important tip is that whatever photo or graphics software you use to print photos, never forget to preview your photo before you send it for printing. The Preview shows you how the overall image will look like after printing.
Dec 09, 2010 | Canon CP-220 Thermal Photo Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Lots of left over paper
Go to this site
http://www.google.com/products?q=cannon+cp-220+printer++ink&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=4&ct=title
Hope this helps. Bud
Jan 06, 2009 | Canon CP-220 Thermal Photo Printer
Cannon photo printer cp 220
cleaner? as in the electronic version..those printers can get crusty when not used..might be some deposits inside the cartridge carrier area
Mar 20, 2008 | Canon CP-220 Thermal Photo Printer
Thanks galatron, you were right.
Here's a picture of the broken part (the white plastic part on the right).
May 16, 2007 | Canon CP-220 Thermal Photo Printer
Canon CP 220- HELP
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=259&modelid=10073 Here is site for your printer. Try unplugging (from the wall and computer)the printer for a few minutes let it clear out the memory etc. Or even download and install the latest drivers. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Canon CP-220 Thermal Photo Printer
184 people viewed this question
jasbo
jasbo
