Question about Acer Computers & Internet
How to get bottom plate off - Acer Computers & Internet
    Sergeant:
    Champion:
  • 275 Answers
Excuse me ....
can u be more precise
Posted on Nov 01, 2008
How do I replace a carpet pro brushroll
How may vary depending on your specific model but you need to make sure it's unplugged from the electrical outlet, lay it flat on the floor so the bottom plate and brush roll are facing up. Remove the bottom plate screws and the bottom plate. Pull the brush roll out and clean out hair, dust and lint. Put new belt around motor shaft and put brush roll through the belt and pull on brush roll to stretch belt far enough to put back in vacuum. Install bottom plate and spin brudpsh roll by hand to insure it isn't restricted before you turn it back on.
Jan 05, 2017 | Carpet Pro Vacuums
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
How to take hood of hoover u6437-900 vacuum cleaner
Hi! The hood on the cleaner shouldn't be removed. If you want to access the belt or the brush-roll the bottom place can be removed. To remove the bottom plate Disconnect cleaner from outlet. Use a Phillips screwdriver to remove the 5 screws on the bottom plate. Lift off bottom plate. Hope this was helpful!
Aug 01, 2014 | Hoover Vacuums
The noise of the engine big, the engine compartment has vibration
Lift the vehicle engine, can see the bottom plate Kepeng traces. If the roadwith obstacles and forced through the bottom plate, the engine must beknocking. The bottom plate deformation and engine oil bottom shell distance, if the distance is too near, when accelerating oil bottom shell and bottom platecollision sends out noise and vibration. So, traffic must carefully observe the road, do not cause drag bottom phenomenon. remove thebottom plate, flat correction can be.Use obd2 for automotive diagnostics , you can improve vehicle safety performance and driving more safer.
Dec 09, 2013 | Ford Cars & Trucks
Height adjustment plate carpet
There is not a height adjustment plate on the vacuum. There is a bottom plate which is the part that glides across the floor. It has three plastic screws which you turn with a large screwdrive or a coin to remove the bottom plate.
Sep 17, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can't find my owner's manual ... how do you take the waffle plates off to convert to a grill?
Not certain if you're still interested in this, but there should be one spring clip on the top and one on the bottom which hold the plates in place.
One is located on the bottom, near the right side of the hinge.
This is the one on the bottom. Sorry about the image quality, but the limitation of 100K means I cannot get a much larger or clearer image.
This is the spring clip which holds in the bottom plate. Note that it is near the hinge in the rear of the unit, right-hand side.
This is the little clip in the front (there is one on the top and the bottom near the handles) which actually holds the front of the plate firm to the unit. This clip does not move, but it is necessary to get the plate under this clip, before securing the back with the spring clip.
I hope this helps. Note that you should be careful not to damage the non-stick surface when you work with the plates.
Jul 25, 2012 | Cuisinart Kitchen Appliances - Others
Bottom spray arm hits plates on lower shelf
That will only happen if the bottom basket is severely distorted or if the design of plates you're using means that they project below the bottom of the basket.
The first problem is fixed by straightening the basket or replacing it; the second one can only be fixed by experimenting with different ways of loading the plates to avoid them projecting down through the basket or by using different plates.
Mar 15, 2010 | Dishwashers
Getting facelate off ???
use a butter/table knife (not sharp) and slip it under the plate at the bottom. pry the bottom off while pushing down on the top and it should pop off. once the bottom is off, push down on the top while pulling and twisting the loose bottom and the plate should come off. you then have access to the parts for the ice/water dispenser.
Jul 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
