This singer (simple), the fabric no longer fed through, so the needle continued to go through the same hole. Then, the machine would no longer make a revolution! I slid the little jagged fabric feeders (inset in the plate beneath the foot. These feet, I slid. This allowed a full revolution. So I know what blocks the revolution is in the fabric feeders beneath the foot?
SOURCE: bobbin thread not able to feed itself to top thread
Number of possible causes. First thing I would check is the timing, impossible to describe how to do it, sorry I cannot help anymore
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
SOURCE: Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
SOURCE: The needle constantly breaks while embroidering.
My foot does this with different thickness of fabrics, it will make the foot land in different, areas, sometimes making the needle hit the foot. Always check needle position before you start embroidering. once your hoop is ready, check the clearance. I often have to use a small roll of non slip material under the foot handle, the one used to bring the foot down. And I use this to adjust the needle postition so it will always land in the middle of the embroidery foot. There is also a way to adjust the height of the needle arm but that's too complicated to get into here and I've never personally tried it.
SOURCE: i have a singer simple sewing machine and when i
Sounds like your feed dogs are in the down position. Make sure they are in position "A" (see picture)
Also, make sure your length dial is set to a medium setting (Usually 1.5 - 3)
