Question about Samsung PLK405 40 in. Rear Projection Television
Trouble Codes - Flashing lights.
My PLK405 is between 5 and 6 years old and the last few months the tv would go out once in awhile and then I would shut it off and open the fan area etc and get it to come on. Now when I turn it on I get the lamp light to flash a couple of times and then all three lights in the front do a continual flash. I am hoping it is just the lamp as I can uy one of those online cheap enough (and it would be just about replacement time). However, if I need to invest in a repair call and a lamp, etc. then it may not be worth it versus buying a new set. Does anyone know if all three lamps flashing is the code for a bad lamp (or more)? Can I safely replace the lamp myself without dealing with high voltage risk? (I am not a technician but not totally without an electronic IQ). Thanks!
    Sergeant:
  • 337 Answers
Looking at the lamp itself can give a very good idea of its condition,You should be able to remove the lamp safely from its compartment because you will not be close to the high voltage but make sure the set is totally unplug from the wall.There might other reason but the lamp is a good place to start.
Posted on Sep 22, 2006
New 60ph6700 hd 3d tv /watchind hd sports fuzzy grass and background/once in awhile lines run through screen/its only two wks old??
Anything new has a chance of failure the first month or so from cold solder joints on circuit boards. If it passes the first month it may last 8 or 12 years. Send it back under warranty.
Nov 29, 2013 | LG 60" 6700 Series Plasma HDTV - 60PH6700
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
TV has no sound or picture
for this set you have !!
wow do this for me OK
with the set turned off press INPUT and MENUE on the front of set.
now count the flashing led.
it will pause for a secon number count on error code
like one blink then fast two blink this is a error code of 12 meening set is ok but then ther are manny other codes.
i need the code to help you out.
thamks,
daniel.
Jan 11, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Whats wrong?
D4 is an indicator that there are trouble codes stored.Trouble codes on that year Honda are pulled manually.Once the trouble codes are identified,there are diagnostic routes to follow to determine the problem.
Jul 02, 2008 | 1992 Honda Accord
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Samsung PLK405 40 in. Rear Projection Television Logo
91 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
