Visio 42" HD display
My Visio 42" HDTV picture gets extremly fuzzy and pixalated and has a posterized effect, then the picture will get clear. This happens over and over again. Help.
  • ddictson Dec 31, 2008
    Same problem. Using TIVO and have cable. TV, DVDs, everything looks like a cartoon and picture getting darker to the point it is hard to see.
    Scholar:
  • 124 Answers
Hi, Does this happend on over the air channels ( not using a cable box) or does this happend on all input line ( DVD player). Thanks, Mike H
Posted on Nov 02, 2008
My ns-lcd42hd09 insignia tv only displays the right side of the screen clearly until the tv is on for about an hour then it will display both sides correctly. Today it never cleared up, stays really dark...
Having same problem. Smacking it or applying pressure often works. Extremely annoying (inconvenient) that a nearly $1000 machine breaks down very soon after one year ( how long the warranty is, of course)
Feb 15, 2011 | Insignia 42" LCD Flat-Panel HDTV
Picture is fine for about an hour then goes fuzzy
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
Sep 12, 2007 | Dell W4201C 42 in. Plasma HDTV
Sp42a we have sound but no picture can this be fixed
there a Plasma screen defect, needs to be checked by a tech. send to repair.
Jan 02, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Picture is not clear, how do I fix it?
I assume that you are dissatisfied with the quality of the picture on the HDTV. Are you feeding it with an HD signal. First, it must be an HD source, either over the air HD or a cable channel in HD (not all "digital" signals are HD signals). Second, you must be sending it with the proper cable, either HDMI or at the very least RGB Component Cables (not composit video).
It is quite common to see standard definition on HDTV's actually look worse than on standard def sets. The reason is the extra pixles availble on the HDTV make you realize how low of resolution the standard def signal is. Instead of it just being fuzzy or unclear, it will actually look bad.
May 28, 2009 | Vizio VW42LF 42 in. LCD HDTV
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Lg 37in the picture cquality in hd is sometimes fuzzy
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to swith to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate. I hope that helps :o)
Jan 15, 2008 | LG 42LC2D 42 in. LCD HDTV
FUZZY (SNOWY) PICTURE
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
Dec 24, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
260 people viewed this question
Top Televison & Video Experts
Electro Med Services...
