We put an in-line water filter WHCF-IMTO in the back side of this fridge because it didn't come with one, I think maybe its time to change it out because the ice is starting to smell bad. I was wandering how to go about changing it out, do I unplug the fridge and take it off or leave it plugged in. and also is there another filter that needs changed out while I am changing this one? Thanks
You can leave the fridge turned on but make sure you shut off the water and put a container under the filter when you remove is as there will be water that will try to go everywhere. Any filters are external so if you had to add one there won't be any others to change, Make sure you flush the new filter to the instructions when it is replaced.
Testimonial: "I went to Lowe's and bought a new filter and installed it, that fixed the smell in the ice. Thanks. There was a little turn off switch thingy connected to the water line and I turned the water off from there, I didn't need to go outside and turn the main off. Thanks for the advice. :)"
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
SOURCE: Burning Smell
go to the appliaces store and buy an rc4 three in one reley its simple to put on and more than likely the culpret it you have any promblems putting it on reply to me esp if the reley thats on it is white
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
All items stored in the refrigerator and freezer should be stored in sealed packaging. Frost free refrigerator operate with a very low humidity and will pick up odors from products. Somewhat of an ozone smell will be in some frozen foods. This is a normal condition. Deodorizing packs are available on the market to absorb odors. Baking soda does the job in most cases.
SOURCE: refrigerator smells strange
I may have found the problem. I pulled out the Fridge again. The odor was in the water pan.
What I found was that the cooling grills in the front was caked with dust. I vacumed this area but it was not until I got down with a flash light and saw this issue. I took a small duster that uses static to pull the dust out. There was a lot. I will see if the smell starts up again.
