Question about LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher LG Dishwasher Model LDS5811WW I have an error code LE, what does this mean?
  • mzitter Dec 19, 2008
    Works fine for several days, then seems not to pump out during cycle.  I can make it pump out by starting a new cycle and letting the initial pump out complete - so it isn't the pump.   Somehow, intermittently not getting program signal to pump?
  • Untooler Jan 06, 2009
    My two year old LDS 5811 just cratered with an LE code for motor failure or electrical harness. But it made accelerating cyclic noise several times before dying and throwing up a parting LE finger. Month out of warranty. Repair good money after bad from whaat I see online. Junk. Cost about $350.00 per year for two years use. Going to the street for trash haulers.
    Scholar:
  • 50 Answers
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Posted on Jan 05, 2009
  • Tripp REa Jan 05, 2009
    The LE code means motor failure, a problem reported fairly frequently for this make and model of dishwasher. Sorry for the bad news.
LG Dishwasher runs to about half of cycle than code comes up on screen with FE
"Water Overflow Error"?
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/413-200-684362-/LG-FE-WATER-OVER-FLOW-ERROR-Water-continuing-to-enter-machine-LDS5811WW
Dec 01, 2017 | LG Dishwashers
LG DISHWASHER LDS5811WW HAS ERROR CODE LE.WHAT PART DO I NEED?
check for broken wires... if still cant find the problem take motor off and spin the shaft. if there is resistance then you need a new motor
Aug 08, 2010 | LG 24 in. LD-12BW5 Free-standing...
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
I have an LG dishwasher model 6810ST that comes up
LE means ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
You'll have to disassemble the unit and make sure nothing is stuck in the pump or locking the blade.
Otherwise you may have a loose wiring connector
Nov 16, 2009 | LG Dishwashers
Error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
Sep 09, 2008 | LG Dishwashers
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
470 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
