Question about Yamaha HTR-5650 Receiver
Help front panel wont work and treble +10 keeps coming up by itself
My Yamaha Amp is not functionaing correctly after moving house. The front panel is completely locked up. Remote works fine but I can not press any butons manually on the front of the unit also when tuning on the amp sometime treble +10 keeps coming up and I cant change the treble on the front panel as its completely inoperational...any ideas.. No previous problems experienced before we moved??? Tried unpluging unit to reset it and made sure the Mem.Guard has been switched off. Help
    President:
  • 3,130 Answers
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Posted on Sep 21, 2006
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have a yamaha r1 2007 and the brake light doesn't light up when you pull the brake lever. What could the problems be?
Does it work fine with rear brake just not with front? If so...inspect the brake switch on the front lever...might be loose so the lever can't press against it.....or remove lever and inspect how the switch is activated (lever presses against it or moves away) and try moving the plunger by hand.
Could also be a loose connection on wiring to the switch.
If neither front or rear work...check fuses, light socket and wiring to the light.
Wiring damage under the seat is common on many models of bikes...the wires get moved then pinched under the seat.
Apr 05, 2011 | Yamaha YZF-R1 Motorcycles
Hi how to open fpa
The front panel lock can only be unlocked with the remote. Press Menu, then Ch+ or Ch - to select Preferences. Press Ok then use the Ch+ or Ch- buttons to highlight FPA (front panel) lock. Then use the Vol+ and Vol - buttons to select On or Off. Then press Menu repeatedly to exit the menu system. With the FPA lock disabled, you can turn it on from the front panel of the TV by pressing the Menu button. However, with the lock enabled, you can only power off the TV from the front panel.
Since the Input button is also only on the remote, if you look for a universal remote, choose one with both Menu and Input or Source functions. Then try all the RCA codes until you find one that makes all of the remote functions work. The original remote is: RCR130TA1 . A substitute remote that should match all of the functions is available here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=13004957447460 .
The manual for the RCA 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . If the direct link doesn't work, start here: http://support.ttetech.com/en-us/productdownloads.html . Select a 20" TV and then your model number in the drop down menus and press Go.
I hope this helps.
Mar 19, 2011 | RCA 20F420T 20" TV
20FP420T FP lock on and can't select input no remote?
Do you mean the 20F420T? RCA doesn't have a 20FP420T as far as I can tell.
Unfortunately, you can't turn off the Front Panel (child lock) without a remote. All of the front panel Power button to turn off the set but not to turn it on. You need a remote that matches the Menu function. Press Menu, then use the Ch+/Ch- buttons to select Preferences. Press OK then press Ch+/Ch- to highlight FPA lock. Use the Vol+/Vol- buttons to toggle the lock function on or off. (Off lets the front panel work normally) Then press Menu repeatedly to exit the menus. A substitute remote can be obtained here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=12994577706920 . This is guaranteed to work with the 20F420T . Most universal remotes should also work as long as they were programmed after 2006.
The manual for the 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . Fill in the drop down menus for 20" and the model.
I hope this helps.
Mar 07, 2011 | RCA 20F420T 20" TV
How do you remove the inside door panel backseat right side of a mercury grand marque 1996
Door Panels REMOVAL & INSTALLATION 1989–91 Vehicles
  1. Disconnect the negative battery cable.
  2. On 1990–91 vehicles, remove the speaker grille.
  3. Remove the retaining screws from the door inside handle cup.
  4. If equipped with armrest courtesy lamps, remove the lens, detach the bulb and wiring assembly from the pull cup and remove the pull cup.
  5. Working through the pull cup opening, disconnect the remote lock rod from the lock knob.
  6. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate, if equipped.
  7. Raise the plate to expose the window switch and power door lock switch and disconnect the switches.
  8. Remove the retaining screws from the armrest finish panel.
  9. Remove the retaining screws from the armrest and remove the armrest.
  10. Using a suitable trim pad removal tool, carefully pry the trim panel plastic push pin retainers from the door inner panel. NOTE: Do not use the trim panel to pry the clips from the door inner panel. Replace any bent, damaged or missing push pins.
  11. Disconnect the radio speaker wiring, if equipped.
  12. Remove the trim panel and watershield. To install:
  13. If the door panel is to be replaced, transfer the plastic push pins to the new panel. Make sure that the watershield is positioned correctly to the door sheet metal. Remove the door pull handle from the old panel and transfer to the new one.
  14. Position the door panel loosely to the door belt opening and route the wiring harness through the appropriate access holes in the panel.
  15. Connect the radio speaker, if equipped.
  16. Align the plastic push pins on the door panel to the holes in the door sheet metal and press the pins into place.
  17. Install the armrest and route the window regulator, remote mirror cable and power lock harness through the access hole.
  18. Install the armrest finish panel.
  19. Install the power window regulator switch plate housing to the armrest connecting the power window switch, power door lock switch and remote mirror bezel nut, if equipped, prior to securing the retainer screw.
  20. Connect the lock remote rod to the lock knob retainer boss. NOTE: Make sure that the remote rod is fully seated into the retainer boss, then function manually or with the power switch to ensure smooth operation of the lock knob.
  21. Install the bulb and wiring assembly.
  22. Install the lamp lens, if equipped, and the pull cup.
  23. On 1990–91 vehicles, install the speaker grille.
  24. Connect the negative battery cable. Fig. 1: Front door panel — 1990–91 vehicles 84170064.gif
    Fig. 2: Rear door panel — 1989–91 vehicles 84170065.gif
1992–98 Vehicles
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front. Fig. 3: Front door panel — 1992–98 vehicles 84170066.gif
    Fig. 4: Rear door panel — 1992–98 vehicles 84170067.gif
    Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front 89600p08.jpg
  4. Detach all connectors from the switch housing.
  5. Remove the door inside handle cup.
  6. Remove the push pin from the door trim panel upper front extension and remove the screw.
  7. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel. Fig. 6: Detach the switch housing electrical connector and remove the housing 89600p09.jpg
    Fig. 7: Remove the door inside handle cup 89600p01.jpg
    Fig. 8: Remove the screws from the door panel in the front and on the upper extension 89600p02.jpg
  8. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  9. Lift the door panel upward and snap out the panel. Fig. 9: There are also retaining screws located in the map pocket as well as . . . 89600p03.jpg
    Fig. 10: . . . along the bottom edge of the door panel 89600p04.jpg
  10. Disconnect the necessary wire harnesses and remove the panel. To install:
  11. Connect the wire harnesses to the door panel, as necessary.
  12. Install the door panel by pushing in and down until it snaps into place.
  13. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  14. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  15. Install the push pin covering screw on the panel upper front extension.
  16. Install the inside door handle cup.
  17. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  18. Connect the negative battery cable. Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door 89600p05.jpg
    Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel 89600p06.jpg
    Fig. 13: Detach the connectors for the trunklid and fuel door release switches 89600p11.jpg
    Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle 89600p17.jpg
Aug 26, 2010 | Mercury Grand Marquis Cars & Trucks
My sis gave me an old samsung tv. It is just for my son and his x-box. Unfortunately there is no remote control. When switched on it is saying PANEL LOCK. Is there any way i can fix this. Model No TI-14N3....
hello you could try this The front panel of the COMBI VISION can be locked to prevent it
from being used by young children for example.
1 To lock the front panel, display the television menu by pressing MENU
2 Select the SETUP option by pressing the P ▲ or ▼ buttons the required
number of times.
3 Press the + button.
4 Select the PANEL LOCK option by pressing the P ▲ or ▼ buttons the
required number of times.
5 Select ON by pressing the + button.
Result: The buttons on the front panel no longer have any effect.
6 To unlock the front panel, set the PANEL LOCK option to OFF.Another option would be to buy a universal remote from say - Argos carefully open it and use your own batteries and use that remote to unlock the TV then return the remote to Argos or if keep the remote if the original is lost. i hope it helps
regards
shaun
Jan 12, 2010 | Samsung Televison & Video
03 grizzly 660 diff lock light stuck on.
Diff lock light on, but 4X4 & diff lock work fine, but light is always on. I tried unplugging both plugins from front diff, but light still stay on. What do I do?
importales@yahoo.com
Aug 27, 2009 | 2004 Yamaha XT 660 X
Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
Jan 26, 2009 | Yamaha RX-V463 Receiver
Front speaker output is not working
Firstly ensure that the 'mute' has not been accidently engaged.
Have you tried connecting other speakers to the same output and cables? If the sound now works, the problem is with the speakers (providing all amplifier settings are correct and wiring is correct). It would be highly unusual to have a problem with both speakers or two sets of cables. Alternatively connect the problem cables and speakers to an alternative source. If they work on an alternative, you are looking at an amp issue.
Aug 29, 2008 | Yamaha RX-V890 Receiver
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Yamaha HTR-5650 Receiver Logo
149 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
