I was on my computer and I was on the internet. Then the computer screen turned into a creme colored screen with vertical lines going down the screen. I cannot exit out of the screen or restart the computer.
  • 781 Answers
1. if your computer is locked up.. try to force a shutdown by pressing the power botton on your tower and holding the bottom pressed until the computer powers down. wait 15 seconds then try to restart again.
if your monitor is the one that seems to be acting funny... try with another monitor or logging into your computer remotely.. if that works, change your monitor, if it doesnt you need to troubleshoot your problem as follows:
2. you may have a video card driver problem: try the following:
last known good configuration
to restart your computer in safe mode by following this;
vista
xp
if you can go into boot into safe mode you do have a video card problem and most likely related with the driver... go to your video card manufacturer and lookf for an updated driver.
3. if you can't boot into safemode.. or not boot at at all you may have a hardware problem and based on the original description of your problem you video card is the one to blame. replace and retest
post your findings, more details of what happened after you restart or more details of your problem
Posted on Nov 01, 2008
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Screen flashes vertical lines when turned on
try a different monitor it sounds just like you think a failing monitor
Jan 15, 2018 | Mag Innovision LT776s 17" LCD Monitor
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Vertical aqua colored line on the screen of my laptop
the cells inside of the lcd itself are starting to go bad which is why your seeing lines on the screen. To fix the problem you'll need to replace the lcd.
In the meantime you can hook up an external monitor and use that so you don't have to deal with lines on a bad lcd screen.
Jun 26, 2009 | Compaq Presario M2000 Notebook
Intermitten snowy picture
well the vertical deflection IC is good but you need to get the conversion chip for it , it controls the vertical , horizontal, color, color alignment ,
it would be wise to get it done soon before anymore dammage is done
Oct 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
