Question about Famous Trails Titan FT600 Monocular
Scope won't power up after storage
Used scope about fifteen minutes over three to four different occassions. Stored scope in bedroom cabinet, in included bag, with batteries removed. Tried to use scope with new batteries approximately one year later. No power.What gives??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
Make sure that there is NO corrosion on the + and - terminals. If there is clean it with a swab dipped in Vinegar, then swab it dry with a dry one. Ther's nothing in the unit that you, yourself can repair unless you are an electronics whizz.
Go to; www.famoustrails.com they are the source for this brand. They also have 'down loadable' 'user Manuals' but I'm not positive that they have one for the FT600, but you won't know unless you ask them.
Good luck. :)
Posted on Apr 23, 2009
Pantech flexp8010 wont power on
time to replace the battery perhaps
Sep 15, 2017 | Cell Phones
Pantech flex: wont power up
This can be due to few reasons one can be a bad battery that won't take enough charge or power cable wire is damaged from inside or may be a phone power issue inside however it'll be better if you can take the phone to a phone repair shop then they will diagnose it.
Oct 02, 2017 | Cell Phones
Whats the difference between an Ottoman and a storage chest?
Ottomans are pretty much the same as storagechests and are used for storage, mainly in the bedroom for blankets andbedding. Ottomans are usually upholstered all around and have a seat on thetop.
May 29, 2012 | Furniture
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
IS THERE A PROBLEM WITH THE BATTERY
Battery life according to Garmin is about four hours with the rechargeable Lithium battery. During the use, it last anywhere from three hours and fifteen minutes to three and half hours.It does happened that sometimes the batter die and won't let the GPS to function properly.
Sep 05, 2010 | Garmin nuvi 255W GPS Receiver
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Microwave shuts down after cooking three or four minutes
Your magnetron is overheating and tripping the thermostat, which interrupts power until it cools.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Famous Trails Titan FT600 Monocular Logo
198 people viewed this question
Top Famous Trails Optics Experts
Andrew Gaitan
Level 1 Expert
Shawn Hudson
Shawn Hudson
Jennifer Green
Jennifer Green
Are you a Famous Trails Optic Expert? Answer questions, earn points and help others
