Question about Garmin GPS
My Garmin Nuvi670 (brand New never used yet) will not receive satellite signal, the s/w versions I have tried are 4.1 and 4.2 - both times the GPS SW Version is shown as 0.00m is this correct ?
  • Caterham7 Nov 01, 2008
    Thanks, that is what I suspected, its a 760 actually, not a 670 but the same result applies im sure.
  • Garmin Master
  • 2,130 Answers
This is not correct. This indicates that there is a problem with the satellite receiver. There should always be a number assigned to the GPS S/W version. If it returns a value of 0.0 this is a problem. If your unit is new, take it back to the store or call Garmin.
- Jim
Posted on Nov 01, 2008
All of a sudden, my Garmin SP 7200 lost all satellite reception. All the signal bars are blank. Garmin says $190 to repair. Really like this unit but considering another unit. Is the GPS receiver...
Try running and installing or reinstalling the latest update using the Garmin WebUpdater.
download the latest version of WebUpdater software
Usually this will resolve most issues.
Failing that, the GPS receiver is replaceable as per Garmin's $190 to repair.
Aug 18, 2011 | Garmin StreetPilot 7200 GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
GPS can not locate satellites.
Where did you try this? GPS signals are "line of sight" only and will be blocked by even thin metallic coatings. Some high-end european cars have window coatings that block GPS signals.
If the unit is new, it may take it a long time to get its first fix, It trys to look for the satellites it thinks it should see at whatever location it last was and at whatever time it thinks it is. After it first locks on to a satellite, it will eventually download new ephemeris data and correct itself, but this may take a while.
make sure you are trying this outside where the GPS has a clear view of the sky. You can go to the system settings page and set your location and time and that will help it find satellites quicker than it would if it thinks it is somewhere else at some other time.
If you still can't get satellites, you may have a bad internal antenna or receiver.
If you have already tried what I suggest, contact Garmin for their free technical support.
http://www.garmin.com and push the support button near the top of the page. There is both phone and email support.
Oct 01, 2010 | Garmin Nuvi 660 GPS Receiver
SW Version Saying 0.00
that's because of the map you have to updata the map and you have to download the quick gps fix
Apr 21, 2009 | Garmin Nuvi 350 Car GPS Receiver
GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Jan 02, 2008 | Garmin 60 GPS Receiver
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Dec 29, 2007 | Garmin GPSMAP 60CSx
Losing Satellite signal
Latest software is 5.20, GPS sw 3.0
Go to the following link for more info on WAAS
http://www8.garmin.com/aboutGPS/waas.html
WAAS doesn't have anything to do with satellite reception.
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
60CSx will not acquire satellites
to find the firmware version go menu, menu, setup, system, menu, software version.
this will show version and unit id
also the garmin sw should show you this info also
D
Nov 18, 2007 | Garmin GPSMAP 60CS GPS Receiver
GPS Logo
203 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
