Question about Kitchen Appliances - Others
Have European Swarovski chandelier wblack/brown pair wire, green and blue separate wires, need to install in USA
I have a Swarovski chandelier that I bought in Germany; I need to hook it up in USA; it has a black/brown wire pair, and a separate green and blue wire, for a total of four wires. I figure green is the ground, but I can't figure out how to hook them up with my American wiring.
    Scholar:
  • 68 Answers
This will probably take a meter, first prove the green is ground with an ohm meter from the green lead to the frame or case, if so, we know what to do with that.
next, I need ohm readings between the remaining three leads with NO POWER and switch on.
For example between black to brown 10 ohms, from blue to black 5. from blue to brown 5 ohms, whatever it is, or if they have no connection at all.
From there we have a good start.
Will
Posted on Nov 05, 2008
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
GE Network & Coax Wall Plate has 8 wires of solid colors. My CAT5E cable has 8 wires, only 4 of which are solid and correspond to 4 of the solid colors on the wall plate. The other 4 wires on the CAT5E...
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Jun 05, 2011 | Computers & Internet
Wire coming into electric shower has Red (Live) Black (Neutrl) Yellow green (earth)Wire in the shower unit is BLUE & BROWN and the Earth which one of the BLUE and the BROWN wires is the live and the...
hello martin, you obviously have one three fase cable for swiching in power. If we consider european standards the blue is neutral ; 2 blacks and brown are phases = live (now the red one here is bit more than usual in european cables) becouse they have only 5 wires and you mention 6.
  • you must inspect the ends with ohm meter and realise the right way to swich it.
  • you might have one relay inside your device and you might need to measure wire colors after relay, so be pacient and go step by step.
Mar 02, 2011 | Home
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
Providing modem output to house addition
Looking at the image in the link below, your computer only uses the orange pair and the green pair. You could break out the blue pair and brown pair and actually run 2 separate phone lines through this cat5e cable also. For reference this image is shown with the end of the plug facing you. The only issue I see with this is to make sure you know which 4 wires you are using in the 12 wire cable and connect the orange pair and green pair to the same wires on both ends. (Do the same with the blue pair and brown pair for your phone line.) If you need any further assistance please feel free to contact me.
http://www.beginnercode.com/wp-content/imgupload/cat5e_T568B_Wiring_Diagram.gif
Oct 30, 2009 | Computers & Internet
Wiring of Ethernet cat6 cable for computer to the modem asm32 to excess to internet
Pinout is as follows:
http://www.mae.ufl.edu/sysinfo/cat6_cables.htm
Looking at the Cat6 connector with the lock tab facing up, look at the pins, (brass colored contacts) going from left to right.
From the left it's pins 1,2,3,4,5,6,7, and 8.
The wires are twisted together in pairs.
First pair
1.Pin 4 goes to the White wire with Blue bands.
2.Pin 5 goes to Blue wire.
Second pair
1.Pin 1 goes to the White wire with Orange bands.
2.Pin 2 goes to the Orange wire.
Third pair
1.Pin 3 goes to the White wire with Green bands.
2.Pin 6 goes to the Green wire.
Fourth pair
1.Pin 7 goes to the White wire with Brown bands.
2.Pin 8 goes to the Brown wire.
Apr 15, 2009 | Avaya Computers & Internet
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Cat 5 Issue you replied to
The color is not so important as the cable follow the same standard on both ends.
It has been my misfortune to find non-standard wiring in a facility, so long as they keep the relationship of the pins the same it will work, if the installer did not then you cannot trust any of the work and MUST either redo it all or have it all tested and certified by a cometent network cable installer.
568-B Wiring
Blue/White 4
Orange White 2
Green/White 6
Brown/White 8
568-A Wiring
Blue/White 4
Green/White 2
Orange/White 6
Brown/White 8
Apr 21, 2008 | Computers & Internet
Kitchen Appliances - Others Logo
320 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
