Question about BenQ FP91G+ 19" LCD Monitor
BenQ FP91G+ 19" LCD Monitor black screen
My monitor went black suddenly while the power button still shows green. Any ideas what happened ?
Thanks for your help,
Jamel
  • jmoula Nov 04, 2008
    Thanks for this valuable information. What will be the best way to
    proceed for finding out whether it is the backlight lamp, its
    associated power supply or the main power supply. Thanks
  • Anonymous Nov 04, 2008
    Monitor went to sleep as normal but when I moved mouse to awaken it, it flashed only briefly and stayed dark. The LED went to green as if it had awakened.
  • BenQ Master
  • 5,568 Answers
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
  • Steve Allison
    Steve Allison Nov 04, 2008
    Depending on how that unit is built, you may be able to see some light leakage from the backlight through the rear of the monitor or it may be necessary to remove the back panel to gain visible access..
    If you can, then you still don't know whether the lamp or its power supply is at fault.
    If access to the circuit boards is possible, inspect them carefully for any signs of hotspots that can be revealed by discolored board areas or components that have failed and affected their appearance; for example; capacitors (cylindrical packages anywhere from 1/4" diameter to close to 2"), any black components with a cylindrical or rectangular case that appear to be split or show signs of having overheated; these will be semiconductors of various function and should never show any signs of heat damage.
    Capacitors will often show a failed state by having a bulging or burst top, or any crystalline deposits around their base on the board.
    If you do see some evidence of failures, replacing only the visibly damaged parts may not help as components are often victims, a symptom rather than the source of failure so without having some measure of knowledge and at least a multimeter, your chances of success are limited.
    It may be time to consider replacing the monitor since the cost of labor and potential problem procuring parts may make the repair too expensive to complete.
Monitor suddenly went black.If on/off button pushed screensaver briefly flashes on but then back to black screen.Green power light is on but nothing on screen when using computer
Try to replace all bad capacitor on power inverter board and turn it on. Hope it will work perfectly.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth...
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Oct 11, 2010 | BenQ FP91G+ Monitor
Benq FP91G 19'' fades out
Capacitor problem on the power board internal solder fix is possible.
Jan 31, 2010 | BenQ Computers & Internet
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Small text and Icons
sir
sheza
i think you r installed any lan card ar etc. when you had taken com thing from the shop he will geve garenti for minimum one weak. for each component they geve a instaltion cd please instal. and see the system requiredments and proseed to ti ok
Mar 25, 2008 | BenQ FP91G+ 19" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Monitor turns it self off
exact same thing has happened to me. I have been told it's some part which often burns out on lcd's which can be replaced easily...
Sep 18, 2007 | BenQ FP91G+ 19" LCD Monitor
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
BenQ FP91G+ 19" LCD Monitor Logo
810 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
