Question about Nokia N95 Cellular Phone
Battery and connection
Basicly ive got a n95 8gb thats a month old and all of a sudden its loses connection to the network after about half an hour of being on and the battery goes flat really quickly even when turned off
    Brigadier General:
  • 7,752 Answers
Try a reflash of the phone take it to a mobile service center and have that done
Posted on Nov 02, 2008
Air hogs assault wont charge
The batteries are too old , or have not the mA of the toy need. Check out the both inconvenience.
Jun 20, 2013 | Toys
Loses internet connection after about 30 mins. Can't repair. Says it's connected when it's not.
>> try reinstall lan drivers
>> any antivirus which is scheduled for specific task.. may creating prob
>> last and best option format and install new OS with necessary drivers
Dec 18, 2012 | Advent Computers & Internet
Losing network connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 19, 2012 | Toshiba Computers & Internet
I recently installed 4 speakers, a deck, an amp, and subs into my truck. About 8 hours after I installed them the speakers suddenly went down, the subs kept thumping, but the speakers are down.
The speaker wire connected to the amplifier if you used one could have come lose or in the back of the cd deck could have come lose. Just check those basics first to make sure everything is strongly connected and make sure you have the correct gauge wire because if you have something rated to high or too low it might not create a solid link
Sep 20, 2011 | Car Audio & Video
I have a Husqvarna 357 xp which is about a year and a half old, but has had very little use for a professional saw. I was cutting with the saw upside down when it suddenly cut out. After letting it rest...
The carb is an "all position" type and shouldn't be the problem.
Check and clean/replace the fuel filter in the tank. Dirty or old gas, sawdust and/or water etc. settle on the bottom of the tank; and when the saw is turned over will plug the filter, causing the symptoms you discribe.
It is possible, if you used old gas(3 to 6 months) that small varnish particles have gotten through the fuel filter and have pluged the fine screen in the carb(located under the diaphram).
Sep 22, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
3 month old new phone. samsung tocco lite. battery problem
1) faulty battery - you'd need to get a replacement from the manufacturer (should be free if still under warranty)
2) when you initially charged the battery after purchasing, if you used it at all before it was completely charged it won't hold a charge.
3) if you live or travel in mountain area, phones lose battery power quicker due to an increase in elevation and distance from nearest tower.
4) if phone has been exposed to moisture or direct sunlight for an extended amount of time, it can damage the phone's ability to hold a charge.
honestly, your best bet is to replace the battery & allow it to charge for 24 hours in "off mode". if the problem persists, then send it in to be repaired.
Mar 19, 2010 | Lands Phones
Wireless router loses setup data
If the power lost power for at least an hour it loses its entire configuration. There is no current fix for this that I know of
May 03, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
GSM wont turn back to EDGE on my Blackberry Curve
Go to "manage connections". Choose "mobile network options" and change the network selection mode to manual. The phone will search for a minute then show a list of available networks. You should be able to select Edge from there.
-Neil
Aug 03, 2008 | AT&T Blackberry Curve 8300 Smartphone
Motorola k1 loses network constantly even when still
I think with this model phone motorola is having network problems.....so take it back to the store you bought it from.
May 30, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
