Question about HP Color LaserJet 2600n Printer
HP 2600n gray background darkness throughout paper
My laser printer shows dark spots all the way down the paper, especially on the left side, but with no measurable distance between the blotches. Also the background on white paper prints out gray. The ETB does have particles of toner on it that I can gently remove, but the problem comes back immediately. Should I replace the ETB or is this some other problem?
  • afsfsa Nov 03, 2008
    Normally any kind of "ghosting" is due to the fuser going bad, especially if the laser printer has been used alot. Before I take a leap into replaceing the fuser, I wonder if the EBT has anything to do with it. I too see areas on the EBT that contain the same pattern of excess toner corresponding to the streaking on the paper.
    I have run the secondary menu EBT cleaning with out improvement. I do have the older firmware. Although I probably need the firmware update, but I think my problem goes beyond that patch, going by my instincts having seen and repaired other laserjets.
    Note that this printer at first had the firmware issue where ghosting appeared when the printer first run. But it went away. Recently the printer was off for several months. We now wanted to take another look at it, at first it was printing great but remember the old saying, if it ant broke dont fix it, well we got to ambitious and ran the fuser cleaning option in the service menu. The page began to print clean but then a ugly streak of toner appeared half way down the page. And thus continues. Yeah, I can kick myself.
    I am going to try to further isolate if it is just the fuser or anything to do with the EBT. As I do not fully understand how the EBT works and its roll in possibly effecting image quality before I can rule the EBT out. Just being cautious before dumping money, as stuff adds up and at some point its better to just buy new. I know its such a waste but thats the world we live in.
Ehh, after futher reading it seems, as long as the EBT is not physically damadged, it is fine. So it all points back to the fuser. Ebay for $75 genuine HP.
But for others, just to rule out anything simple, disconnect from computer, and reset to factory defaults. Print Demo page. If still looks ugly, nothing to loose, run the service menu cleaning option, basicly heats the fuser very hot and passes a paper very slowly to catch any excess toner. I have never seen this cleaning option help but you never know. And if your print still looks like ****, you can save your beloved slow printing laser jet, replace the fuser.
Awsome instructions...
http://h20181.www2.hp.com/plmcontent/NACSC/SML/results.htm?SID=446153&MEID=B67763C2-AD42-45FD-B0E6-7D5998FCE86D
Posted on Nov 03, 2008
    After further observation and thinking about the imaging processing, I focused on the black toner. Upon further inspection it seemed to be "dirter" and I noticed a "similar" excess toner on the same side of the roller as on the paper. I then sook the cartridge vigourously side to side and got toner all over me. But afterwards, the print is PERFECT again. Looks like when we were cleaning the unit previously or whatever, it messed up the cartridge. Looking good.
    The clue was uneven streaking, and NOT a perfect repeating image "ghosting". It was the cartridge. Note, I have seen similar excess toner streaking in other laser jets, with new cartridges, that required very vigourous shaking to clear the excess toner. Just needed time to think it through.
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
Double printing, especially down the left hand side of page
replace fuser,if still happening replace transfer belt
Apr 30, 2009 | HP Color LaserJet 2600n Printer
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
HP 2600 COLOR PROBLEM
I am not sure what out of position refers to but if it is a setting in the printer this should fix it.
Restoring the factory-set defaults returns all of the settings to the factory defaults. Restore the factory-set defaults
  1. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Service, and then press c00317851.gif (SELECT).
  2. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Restore defaults, and then press c00317851.gif (SELECT). The device automatically restarts.
  3. Hope this helps
Mar 24, 2009 | HP Color LaserJet 2600n Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP 2600n printer
1-st of all remove the dark blue/gray top cover - from the back/top of the printer there are in L and R side 2 holes. Stick a slim screwdriver to release boath locks and lift it up. Under this cover U'll find 4 scrwes. Before lifting the white cover remove the R printer cover for removing the control panel cable. Once U remove the white top cover U can access the fusssing assambley.
Good luck.
Mar 11, 2008 | HP Color LaserJet 2600n Printer
HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Dec 15, 2007 | HP Color LaserJet 2600n Printer
Dark spots on my paper
is there a corona wire sliding cleaner on the drum assy? if so it should be firmly at the correct end of its travel - on some printers if it is inboard it will print aline down the side
Apr 18, 2007 | Kyocera Mita FS 3800 Laser Printer
HP Color LaserJet 2600n Printer Logo
1,404 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
