Question about Cyberhome CH-DVD 300 DVD Player
Do i need an rf modulator to install cyberhome dvd player to hd receiver?
I am trying to connect my cyberhome 300 dvd player to my directv hd receiver. do i need an rf modulator?
  • mollyjeb Nov 14, 2008
    I need to mention that I bought an HDTV. I think when the DirecTV installer installed my HD receiver with the new HD Dish, he may have wired the Cyberhome dvd player wrong. I get audio, but no video. He has the red, white and yellow wires coming from the back of the DVD player from "video out", into "video in" on the TV. On the back of the receiver, he has the coaxial cable coming out into the TV, as well as 2 other plugs going into the back of the TV. Did this help to describe my situation? I don't thing I need my RF Modulator if I have HDTV, do I? Shouldn't the DVD player be plugged into the receiver? Thanks for your help!
  • 147 Answers
Probably. I recommend posting a photo of the back of each unit. If the DT HD box only has an F coax connector for an aerial input, then yes, you'll need a modulator.
Posted on Nov 11, 2008
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
Y Pb/Cb
CH-DVD 300
. Plug the DVD player's electrical
plug into a wall socket or power
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
You can find an quick install wiring schematic at, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver plug the rca cables into the FRONT of the Magnavox will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Connect satellite receiver to dvd recordrer
there is really no way around it. Directv and Tivo are releasing a new receiver in a few months. Or you could purchase a HD dvr. Directv's receivers dont send any guide data thru a RF output, only picture and sound. The recorder you have is great for cable.
Jan 06, 2009 | Televison & Video
Need remote codes
I have DirecTV and I have the same remote and I read somewhere you can use the codes for Sampo. I found the codes in the DirecTV remote's manual. The first one I used worked. Hope this helps!
Dec 30, 2008 | Cyberhome CH-DVD 300 DVD Player
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
HDTV Antenna
Most brands of the HD antennas are good. Use a powered one if possible. For the Cyberhome device, you have to watch them. If purcahsed at Radio Shack or any other retailer, see the website for them. It would be a good bet a Google search for the model will lead you to it. Cyberhome equipment does not have a good reputation for longevity.
Apr 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
