PDAs
Problem for PDAs
Generic problem for all PDAs
Hi, On my grundig vp6200, everytime
By liamf327 on Nov 01, 2008
On my grundig vp6200, everytime I turn it on it has an error message that is not understandable to read. The only way I can overcome this problem is to click a box which then takes about a minute to load. Whenever I connect my USB cable it says 'installing device driver' which goes on forever. Also, the battery seems to be failing everytime I turn my device on and auto powers itself off. If you could help me with these problems, I would mostly appreciate it. Thanks.
Solution #1
posted on Aug 20, 2009
Not Rated)
mickelmas
Rank: Apprentice
Rating: 0%, 0 votes
Hi I recently had the same problem with my VP6200 and i opened it up back cover only 4 screws 2 at base & 1 each side 1 is behind small metal disc about 10mm diamater.
on opening it up i found the battery had expanded and was putting pressure on the hard disc.
i unplugged the battery connector only 1 way to refit.
and i made 3mm hole at top of battery foil to release pressure then i put pressure on foil to flatten again.
plugged in and presto it lives again.
I understand this problem has been around in pda's and laptops for some time now. Next i am looking for new battery. good luck. mikey
Was this helpful?
Yes
No
Popular Solutions for PDAs
Questions and Unsolved Problems for PDAs
Answer
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? ... (More)
Answer
I want a product similar to Palm m505 to store data only.
Answer
my TX screen/stylus alignment is off: at the bottom of screen it is necessary to tap more than the... (More)
Answer
Resetting phone to original settings. When it gets to set 2 of 4 it says, "Press the letter... (More)
Describe your PDAs problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in Van Nuys, CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
