Question about Maytag MDB7100AWB Dishwasher
Dishwasher won't start
I plug in the dishwasher and the lights come on and then I push the start/ cancel button and nothing happens
  • 734 Answers
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Dec 02, 2008
  • 5 Answers
SOURCE: dishwasher does not turn on. it is plugged in but
These are just some possible solutions that are worded for general assistance, I'm sure you have checked many of these things but others may not have;
The circuit breaker in the electrical panel may need to be reset. Hopefully it is labeled and will be easy to find without cycling power to everything else in the house.
The dishwasher may be on a GFI (ground fault interruption) circuit. The outlet may have a reset button on it that needs to be pushed or the circuit breaker in the electrical panel may have a built in GFI that needs to be reset.
Many dishwashers are installed with a light switch in the vicinity of the unit that is used as a disconnect. The light switch will cut power to the dishwasher if turner off. The switch is sometimes above the counter and sometimes below the sink.
There is also the possibility of a faulty On/Off button or dishwasher circuit board.
Posted on Dec 27, 2009
SOURCE: Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Posted on Oct 20, 2007
SOURCE: Clean light on dishwasher won't stop flashing
Reset worked for me. I had the same problem as others. Thanks for your help.
Posted on Nov 10, 2008
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
SOURCE: My Trionr XL dishwasher will not run. I push the
It sounds like your dishwasher might be locked. You unlock the dishwasher by pressing the "heated dry" button for three secs. and then releasing it, that should do it.
Posted on Jul 18, 2009
Kitchen aid dishwasher model KUDS301XBL2 won't start
check and see if its plugged in, it might of came lose from the outlet.
Jun 12, 2012 | Dishwashers
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
It seems when I pushe button to start nothing
Some fault in the dishwasher is causing it to believe the door is not locked.
I would check the door lock.
check this youtube video out for the location of the door switch.
http://www.youtube.com/watch?v=2CqFZ-Ud0nE&feature=related
(quality of video may not be the best but gives an idea of its location).
If you can give me the exact model number I can find out more details of the problem you are having.
May 12, 2010 | Frigidaire Professional Series 24 in....
Washer will not start
Does the dishwasher plug in under the sink or is it hard-wired? If it plugs in under the sink unplug it and let it stay that way for 5-10 mins and see if that changes anything. If it is hard-wired see if you can figure out which breaker it is on and turn it off for same amount of time. Let me know.
Thx
Jul 31, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Just won't work!!
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Jul 01, 2006 | Kenmore 24 in. 16293 Built-in Dishwasher
Maytag MDB7100AWB Dishwasher Logo
511 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
