Question about Handspring Treo 180 Handheld
IR Beam stays OFF
I cannot switch on the IR Beam on my Treo 180, its stays on OFF mode even if i click on ON in general settings, have even tried a warm reset. Please help
0 characters
1 Points
Is the handspring treo300 unlockable?
i just 2 month back got a unlock code for handspring treo 180 t-mobile network got in uk the unlock code at good cost
try here ...
Aug 25, 2010 | Handspring Treo 300 Handheld
Wireless mode of my treo 600 constantly off
have you tried to hard reset the unit - backup your personal data before you do
Sep 01, 2009 | Palm Treo 600 Handheld
Bluetooth for ringtones
instead of bluetoothing them use your beam option just go to the main menue and click on the menue key (it is a button) them go to beam that should work
Nov 15, 2008 | Palm Treo 650 Handheld
My palm treo wont turn on
mine did the same exact thing after i was texting i just clicked the screen off and went to turn it back onand it wouldnt. so i took the battery out and tried a soft reset or whatever, because itll sometimes act up. but it normally works. i called sprint, and they said to go to a sprint store and see what they can do., im praying to god they dont need to do a hard reset. id lose everything on there. ill let you know if they do anything to help. and what it is that they did. im sorry your phone is as mentally challenged as mine.
Aug 19, 2008 | Palm Treo 600 Handheld
Go to settings, connections and run beam.
May 20, 2008 | Palm Treo 750 Smartphone
Treo 650 wont sink
Assuming you are running Palm OS and not one of the rare beta Windows Mobile versions, here is my take on this.
Are you using a USB or Serial Sync cable? With either solution, make sure that the setting on the Palm Desktop Hotsync Manager is set to the correct setting (either USB, Serial, IR, etc). Conflicts between the cable type and the settings on your PC are common.
I prefer using USB cables since they are faster and you can tell if you are connected quicker than with a serial cable. Initiate the sync via your phone or the Palm Desktop Manager software. I have had faulty cable sync buttons and this was a good solution for me. If you haven't tried a new sync cable, you might want to.
Actually if you have time and a laptop, you can take your Treo to a Palm store and borrow one of their cables to try and sync. They were really helpful whenever I went in there.
Good luck.
Apr 26, 2008 | Palm Treo 650 Handheld
Reset both devices and make sure the IR ports are alinged together so that they are in direct contact with eatchother.
The IR should work 0-10 meters id suggest 20cents from eatchother.
Mar 17, 2008 | Palm Treo 755p Smartphone
Receiving MMS on Treo 650
That soulution dont seem possible with Palm treo 650 running Palm OS
Dec 13, 2007 | Palm Treo 650 Handheld
Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Auto-off not working
I heard this happens after updating the Treo 650 with the new version 1.17. Is this your case? If so just remove the new update... Anyway, you can try the soft restart or even Performing a system reset(from the user guide p.170): ".. Performing a soft reset A soft reset is similar to restarting a computer. If your Treo is not responding or you have trouble synchronizing with your computer, a soft reset may help. 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. Use the stylus tip to gently press the reset button on the back of your Treo. .."
Jan 03, 2006 | Palm Treo 650 Handheld
Handspring Treo 180 Handheld Logo
24 people viewed this question
Top Handspring PDAs Experts
Juriy Crook
Juriy Crook
ray gallant
Are you a Handspring PDA Expert? Answer questions, earn points and help others
