Question about T-Mobile Sidekick® 3 Cellular Phone
T-Mobile won't fix my Sidekick 3
I was having the same problem as a previous poster. "My sidekick 3 wont charge by itself. i either have to put something up against it or play wth the wire." After a while that stopped working altogether and my phone wouldn't turn on because it couldn't be charged. I had a warranty plan on the phone and equipment replacement. I called T-Mobile and they gave me some horse hockey about how someone used my phone before me to make a call or something and so that voided the warranty. Hunh? I explained that I bought the phone at a T-Mobile store and saw it get activated. If someone did anything to the phone before me, then it was a T-Mobile employee. they still refuse to fix my phone. Is this because they dont want to take the phone back or what? I just want it fixed. Please help! I spent like $400 on this phone. MY SIDEKICK NEEDS A NEW SIMCARD ,BATTERY AND NEW SCREEN ALSO A NEW CHARGER TO IT ALSO SOME NEW PEACES FOR IT.
  • 226 Answers
Best bet is the mini usb jack is faulty where the charger plugs in to. could be the charging base needs to be re soldered. take it to an electronics tech, or your local service centre.
good luck
Posted on Dec 29, 2009
Sidekick 3 wont charge
There might be something wrong with the charger or you can use a different outlet.
But if there is something wrong with the charger i would suggest to get a new one (:
Mar 05, 2009 | T-Mobile Sidekick® 3 Cellular Phone
The phone will not turn on
The previous poster has a good point, If you have a friend that has a sidekick 3 or sidkeick ID, swap batteries and see if they work.
THe sidekick 3 is notorious for the charging port going bad. It is tricky though, because the little orange light comes on but no power is actually getting to the battery.
In this situation, I recommend a external battery charger and a spare battery.
Check out the link below for those.
Mar 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Tmobile sidekick3 wont charge
It's called the sidekick 3 charging port and they are known to go bad a lot.
You can check out cellulardr for the repair. It runs about 75 dollars or you can get a external battery charger cradel and charge the battery outside the phone.
Feb 17, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 wont go past BATTERY LOW! PLEASE ALLOW DEVICE TO ..
turn off your phone. then remove the battery for 5 minutes. also make sure your charger is not plugged in. then put the battery pack into the phone. it should clear up. also you might have over charged the battery. another solution is to buy a new battery pack and if that does not work your phone is acting up on battery basis
Jan 20, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone wont charge
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 wont turn on
I did the same thing with my phone. You have to replace the screen. It has been damaged.
May 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
hey, my sidekick3 screen won't light up
and my buttons wont light up either.
and suggestions?! please help
Aug 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 has problems
It sounds like the prong in the middle of the AC input is loose and therefore not making a good connection with the charger. What do you mean when you say "it won't come all the way back on?"
Aug 16, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick® 3 Cellular Phone Logo
52 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
